Sign in to follow this
Samusa
How do you attach lights? What glue?
I'm having a terrible time getting my lighting to stick to the walls and ceilings of my house. What do you all use to stick your lights up?
I use tacky glue with a dot of super glue gel.  Are you working with especially heavy lights?
I use Weldbond for almost everything. It is amazing stuff. I do have to sometimes put a little painter's tape over the light to hold it in place til the glue dries.
Thanks ladies. @otterine I resorted to super glue in the end because it was all that would work, I was just wondering if there was a better option. :) The lights are not particularly heavy but the the coach lights on the basement have an uneven surface to adhere too so that probably wasn't helping.
@shannonc60 thanks for the tip. I'll give it a try. Is Weldbond available in Australia? Or do I need to get it online?
Sam, it is available at any hardware store I think. We got it in our little town, so you should be right in Brisbane. It's not cheap but a lot of miniaturists and modellers recommend it.
I tried tacky at first but didn't work for me, they would eventually detach with the weight. Now I use double sided transparent tape, tesa or uhu both have a good grip. I cut a small round portion to fit the lamp and it's pretty easy to hide and detach in case the bulbs need replacing. I use the same for paintings, mirrors etc, so far they haven't damaged any of my wallpapper.
I use Aileen's Fast Grab Tacky with a drop of super glue...and I use tape to hold the light as it is all drying.  It's especially helpful if the wiring goes through to the other side of the wall because I can tape on the opposite side of the wall and the lights stay very straight.  I have never had one come down.
I use glue and superglue like the other ladies. However I had this one ceiling fan that I was trying to glue to a really uneven surface and it kept falling off over and over. I finally resorted to using a teeny tiny piece of loctite fun tak mounting putty and that did the trick. It hasn't fallen off since.
  • Similar Content
    • By Littlehousesplus125
      Dolls House wiring specialist from Small world Products
      Wiring a Doll’s House here is some information you might like to look at, it all works around our SWP Easy-Wire system wiring a Dolls House 1/12th or 1/24th
      Have you check out our YouTube channel
      https://www.youtube.com/user/littlehousesplus125/videos
      There is a lot of information on our Doll's House wiring for Lighting / Fires page
      http://www.littlehousesplus-shop.co.uk/epages/62053002.sf/en_GB/?ObjectPath=/Shops/62053002/Categories/Dolls_House_wiring
      And if you need any help here is the link for you
      http://littlehousesplus.co.uk/about_us_2.html
      By the way we send all over the world
      There are lots more on http://www.littlehousesplu-shop.co.uk
    • By adeshy1
      CJN Miniatures in Edmonds, WA recently moved to a new store at 23030 Hwy 99. It is a yellow 2-story building between Les Schwab & Public Storage. They not only have everything you need for a dollhouse, but also dolls, collectibles & antiques now. They offer consignment at 30% and have many artisan and older items in stock. Visit them at
      http://CJNMiniatures.com
      CONSIGNMENT AGREEMENT-1.docx
    • By deadbird
      Hi everyone,
      I am currently building a doll house and I've just bought a set of small christmas lights and a plastic chandelier with a single glass bulb inside. My problem is, i'm making this as a part of a school assessment to be marked and glass is not allowed. Does anyone know if i could possibly use glue to seal and protect the light globes while making them appear as plastic? Or are there possible alternatives to glass lighting? Any help would be wonderful - I am perfectly fine with flouting these marking guidelines (they are in place for safety for the markers but I'm not sure how a 1cm long broken lightbulb could do much harm). I can post photos if necessary =)
    • By Samusa
      So I'm still on a lighting kick... I bought these cheap plastic lights from China a while ago... They were boring as is, but had good lines. I tried painting them silver with metallic acrylic and a brush... NOT successful!.. So I bought some aluminium spray paint and gave them a good coat. Unfortunately the bumpyness left from the original paint job still shows on this tester lamp. The rest will only be getting spray paint for a smoother finish. I also added some copper tape and some nail art rectangles to the edges before painting, to add a bit of detail to the plain shade and make them seem a bit more chunky and industrial. I added jewelry wire to the inside of the shade to form a simple bulb cage.
      Sorry for the poor quality image of the makeover.. I resized this picture down quite a bit to match the size of the light in original form and it became very pixellated..
    • By Samusa
      Here is a picture of the clip on earring back light bulb & shade holder for Miranda (SewMini).
      Jewelry pin through the middle hole. Light bulb wire through any of the others.  The shade fits snugly onto the earring back, holding it in place.
      The holes in the earring back allow light to come out of the bottom of the lamp as well as the top.
