Paula Posted January 17, 2007 Share Posted January 17, 2007 Hi: New here and have been building a small dollhouse (the orchid) since approx last april. Yikes this is tedious! SO my question is...how do you cut apart the shingles? I've been using a razor blade thing in a holder for the rest of the pieces but the shingles --there are so many of them. I spray painted them red (to match the shingles on our house per dd's request)...but now comes the hard part...cutting them out! Plus what do you suggest to make the angle cuts for the dormer areas? Thanks in advance...Paula !~ who will have more ??'s soon I'm sure! Quote Link to comment Share on other sites More sharing options...
Steve_in_PA Posted January 17, 2007 Share Posted January 17, 2007 They should just snap apart when you bend them. If you have problems & they split, I just use a utility knife. Make sure you have a new or sharp blade in it. I use the same for cutting angle cuts or if you have the time, you can try a hacksaw blade & touch it up with alittle sandpaper. You will have to experiment & see what works best for you. Quote Link to comment Share on other sites More sharing options...
IAK Posted January 17, 2007 Share Posted January 17, 2007 I guess since you painted them first they might not "snap" out so easily. As far as cutting angles etc. I just use sissors :thumb: Quote Link to comment Share on other sites More sharing options...
Paula Posted January 17, 2007 Author Share Posted January 17, 2007 They didn't snap easily before I painted them either...dh suggested painting them first and it made sense so I did. It takes a lot of strength to cut them apart and just takes time! Yikes...lots of time! thanks for your responses! Paula oops ...just saw the scissors thing. Perhaps the tiny cuticle ones? WIll experiment! Quote Link to comment Share on other sites More sharing options...
mamie Posted January 17, 2007 Share Posted January 17, 2007 I like to use scissors :thumb: Quote Link to comment Share on other sites More sharing options...
havanaholly Posted January 17, 2007 Share Posted January 17, 2007 Perhaps the tiny cuticle ones? No, get a fairly sturdy pair. I use my EZ Cutter and cut four at a time to fit. Quote Link to comment Share on other sites More sharing options...
Shakyshaky Posted January 17, 2007 Share Posted January 17, 2007 I use heavy duty kitchen scissors. ( you know the kind that say they will cut through bone) Quote Link to comment Share on other sites More sharing options...
Hallowell Posted January 21, 2007 Share Posted January 21, 2007 I also use scissors. Quote Link to comment Share on other sites More sharing options...
nuttiwebgal Posted January 22, 2007 Share Posted January 22, 2007 I bend mine to take them apart. and to cut angles I use the easy cutter but before I had one I used heavy duty sizzors Happy Building nutti Quote Link to comment Share on other sites More sharing options...
heidiiiii Posted January 22, 2007 Share Posted January 22, 2007 Hi.. I am taking apart the greenleaf shingles now. I used a x-acto knife to split down the seams. Then I cut with scissors to seperate each section. Then you should be able to easily snap each shingle off. Then I take my scissors and cut the rounded top off. It is very tedious. Good task to do while watching a movie. Quote Link to comment Share on other sites More sharing options...
MiniDoxLuvr Posted January 22, 2007 Share Posted January 22, 2007 An x-acto knife and sissors should do the trick. Since you painted them first, you might want to go ahead and paint the edges too in the same color once you get them loose. Tedious I know, but an added touch that will help with the realism factor. Quote Link to comment Share on other sites More sharing options...
Jeffrey Posted March 13, 2007 Share Posted March 13, 2007 what kind of shingles are they? i bought a bag of wood shingles that were as thick as the wood from the kit walls. i used a tile cutter to cut them and it worked well. Quote Link to comment Share on other sites More sharing options...
havanaholly Posted March 13, 2007 Share Posted March 13, 2007 The GL shingles are very thin, like the siding, which makes trimming them to fit easy-peasy! Quote Link to comment Share on other sites More sharing options...
wenlaine Posted March 13, 2007 Share Posted March 13, 2007 I bend them back and forth till they come apart. Quote Link to comment Share on other sites More sharing options...
Bill Posted April 9, 2007 Share Posted April 9, 2007 Okay This may be silly, but I actually didn't cut apart the shingles into individual pieces. I left them attached in long rows and only cut the ends to make them fit. This was with Greenleaf shingles so I can't say what will work with other brands. I also did prestain the entire sheets. I took a dark stain and applied it directly with a stain pad and wiped it off right away with a towel. The stain got into the grooves and made it look like the shingles were individual. I did have to do some touch up on the ends that I did cut, but it was easy just using a cuetip. Hope this helps... Quote Link to comment Share on other sites More sharing options...
havanaholly Posted April 11, 2007 Share Posted April 11, 2007 Not silly, Bill, it works for me, too, except I don't use a stain pad, I wad up a scrap from one of DH's old teeshirts. Quote Link to comment Share on other sites More sharing options...
