CathyAllen Posted May 2, 2020 Share Posted May 2, 2020 What is the best way to remove paint from the plastic sheeting in the windows? I am such a sloppy painter! I only use acrylic paint. I want the windows to be nice and clear! Quote Link to comment Share on other sites More sharing options...
grazhina Posted May 2, 2020 Share Posted May 2, 2020 Spray cleaner like 409, Mr. Clean spray or Fantastick, for example will soften acrylic paint so it can be peeled, scraped or washed off. I've never used it on that kind of plastic sheet, but I've taken acrylic paint off that way on other solid and plastic surfaces. Quote Link to comment Share on other sites More sharing options...
LeeB Posted May 2, 2020 Share Posted May 2, 2020 Have you tried just scaping it with a fingernail? Sometimes with acrylic paint on a smooth surface, it will peel right off. Maybe next time think about masking the clear part of the window or painting the frame before inserting the "glass?" Quote Link to comment Share on other sites More sharing options...
KathieB Posted May 2, 2020 Share Posted May 2, 2020 Gentle scraping with a blunted Popsicle or other wooden stick will probably take it off. I'd try that before attempting removal with a liquid cleaner, which may smear it and/or dull the surface. Quote Link to comment Share on other sites More sharing options...
WyckedWood Posted May 4, 2020 Share Posted May 4, 2020 I know what NOT to use. Fingernail polish remover. I wouldnt use anything more serious than water. Hopefully scraping will help. 1 Quote Link to comment Share on other sites More sharing options...
amyole Posted May 4, 2020 Share Posted May 4, 2020 I try to remove as soon as possible with a cotton-tipped swab and water. Quote Link to comment Share on other sites More sharing options...
