Jennifer S. Posted April 27, 2020 Share Posted April 27, 2020 I started my first electrified dollhouse over 20 years ago. I stopped, because the wiring just got too difficult. I used a CirKit wiring system. I did manage to wire the house, but getting the lights in and wallpapering it properly to work got to be too much. Now 20 years later, I want to get back into the hobby and try doing it again. I’ve read a lot and realized how many mistakes I’ve made. I want to solder the joints, but the Mylar is still on the tape. How do I remove it to solder the joints now that it’s on the walls and has brads already in place? I will also have to rip out some wallpaper to fix the outside entry lamp on the inside. Any suggestions? I want to do it right this time. Quote Link to comment Share on other sites More sharing options...
Sable Posted April 27, 2020 Share Posted April 27, 2020 Just peel the Mylar back. I’ve used my xacto blade to peel and cut it away. Quote Link to comment Share on other sites More sharing options...
Mid-life madness Posted April 27, 2020 Share Posted April 27, 2020 Welcome Jennifer S. I have a love hate relationship with dollhouse electrical. If you quickly swipe the Mylar with the soldering iron, it will melt off of the copper. Quote Link to comment Share on other sites More sharing options...
KathieB Posted April 27, 2020 Share Posted April 27, 2020 3 minutes ago, Mid-life madness said: If you quickly swipe the Mylar with the soldering iron, it will melt off of the copper. But then don't you have melted Mylar on the tip of your soldering iron? In addition to inhaling the fumes from melting Mylar? I think using Sable's suggestion to tease the plastic away from the copper with the tip of an Exacto knife is a much safer method. Quote Link to comment Share on other sites More sharing options...
Mid-life madness Posted April 27, 2020 Share Posted April 27, 2020 1 hour ago, KathieB said: But then don't you have melted Mylar on the tip of your soldering iron? In addition to inhaling the fumes from melting Mylar? I think using Sable's suggestion to tease the plastic away from the copper with the tip of an Exacto knife is a much safer method. That is what Carl from https://cr2s.com/ taught us? Just clean the tip with the tip clean sponge then put a little solder on the tip. Quote Link to comment Share on other sites More sharing options...
havanaholly Posted April 27, 2020 Share Posted April 27, 2020 The fumes of melting mylar are toxic, Carrie. I would also use Sable's method. Quote Link to comment Share on other sites More sharing options...
Mid-life madness Posted April 27, 2020 Share Posted April 27, 2020 So are the lead soldering fumes! Quote Link to comment Share on other sites More sharing options...
Jennifer S. Posted April 28, 2020 Author Share Posted April 28, 2020 Thank you all for your suggestions. If I peal off the Mylar, won’t it pull out the brads with it around the joints? If so, do I need to place new ones in exactly the same place? I have so many more questions. Not sure if I should use this thread or not. Any suggestions on removing wallpaper to get at old connections? Quote Link to comment Share on other sites More sharing options...
Mid-life madness Posted April 28, 2020 Share Posted April 28, 2020 Hi Jennifer, This is the perfect place to ask questions. It is your thread.....so keep them coming and I'm sure everyone will chime in with their suggestions. If you accidentally pull out the brads, you can use eyelets instead. In fact, eyelets are much better to use for connection vs. the brads, and they have a better surface area to conduct through.....Most miniaturists tell you not to use the brads at all. Eyelets are the way to go. I don't know why CirKit still sells them. Normally I put scotch tape over my connections. Are you going to re-wallpaper any way? I hate to say this, but I would probably start over with the tape wire. Give us some more details. I wallpaper onto card stock templates. That way the paper isn't sticking directly onto the tape wire. I have had to go in and fix a faulty connection and it made it easier to fix the wallpaper later on. I also avoid the connections by mitering the tape wire to fold back on itself 5 Quote Link to comment Share on other sites More sharing options...
Jennifer S. Posted April 29, 2020 Author Share Posted April 29, 2020 I’m glad I found the right place. Thank you for helping me. When I started, I tried the eyelets, but for some reason I had a really hard time getting them into the copper and wood, so brads were easier. I ended up finishing the whole first floor with wallpaper and all. I had a terrible time with the sconces and chandelier with the plug-like connection made by CirKit, but eventually they worked with the help of Clairebell brass, although, in time they started to lose the connection. Anyway, only the first floor and part of the second are complete. Then, I later wire taped the entire house. I tried to use the fold method as best I could, but often it needed connections with brads. It’s a big Victorian house with 3 stories made be Real Good Toys. I was thinking if I soldered the brads to the copper, then the connection would be more stable. I can try the eyelets, but I remember having a hard time with them. Since 20 years ago, I now know how to solder. I haven’t started on the house yet. It’s still in the basement, but I’m hoping to bring it up within the next week or so. Then, I can see what state it’s in. The front porch light is hanging down and will need to be reattached from the inside. That’s where I’ll need to peel back the wallpaper and remove the molding. I’ll also have to redo the chandelier, because the wires got ripped out. I attached it from the ceiling to second floor, but the connection was faulty. If the sconces don’t work, I’ll have to redo the whole thing. Probably the junction splice will need to be reattached. I’d hate to have to redo the whole thing. I’ve been reading about what you suggested with using card stock to put the wallpaper on. I’ll do that moving forward. Maybe you’re right, though, that it will need to be redone. Quote Link to comment Share on other sites More sharing options...
Mid-life madness Posted April 29, 2020 Share Posted April 29, 2020 MDF dollhouses are notoriously difficult to electrify with tape wire. You may want to use the round wire system (Sorry). There is a tool that helps with the eyelet insertion, but I haven't used it on MDF. I also have had rotten luck with Clare Bell, but that could just be me! It won't hurt to put solder on the brads. I am not trying to discourage you, just sharing some of my experiences. Bam Bam 1 Quote Link to comment Share on other sites More sharing options...
jbnmini Posted April 29, 2020 Share Posted April 29, 2020 I've done my share of saying "magic words" while doing wiring. I have learned quite a bit and even am getting better at soldering! Yay! You may discover that after so long some of your brad connections have corroded and may need replaced. And you may even want to start over in some spots...I know I've done that often when renovating houses for clients. Removing old wallpaper may be done with a sponge and warm water- some folks add a touch of fabric softener. Doing the folded corners as best you can is a big help - the less connections to cause problems, the better! While MDF may be a bugger at times, using eyelets (and the insertion tool!) is the way to go. Connecting fixtures to the tape wire is best using eyelets as well - even better is soldering! With a craft knife, carefully slice through the clear covering, being careful not to cut the tapewire. Cut down a small length to allow enough space for your wire attachment. Peel back the flap - I hold it back with a smidge of painters tape. Solder your fixture wire and then release the plastic flap back over your wire join. I then use packing tape or scotch tape over the join. As far as sconces.....I fought with-and ruined-far too many fixtures trying to use those plug-in adapters. While they are ok for certain situations, my experience has been that they do not hold a good connection for very long. It is far better to plan your wiring lay-out so that the sconce wires can be put through a hole in the wall and then soldered onto a tape wire run on the other side of the wall. This may require a channel to be cut out of that side of the wall in order to hide the wires. ok- those are my suggestions for now. Good luck! 1 Quote Link to comment Share on other sites More sharing options...
Jennifer S. Posted April 30, 2020 Author Share Posted April 30, 2020 Thank you so much! All wonderful advice. I found my old electrifying kit. Looks like I don’t have much tape wire left, so I’ll need to buy some more and possibly a whole new kit, if I go that route. I’d like to do so, if at all possible, because I know how to do it. I don’t know much about round wire. I discovered I have a special tool for inserting eyelets. It has a wood handle and is called the EZ Punch and says it’s for MDF boards. Do either of you know where to get good wallpaper online? I have the sheets with numbers on them to reorder it, unless they aren’t made any more. Thank you again for the support. Quote Link to comment Share on other sites More sharing options...
jbnmini Posted April 30, 2020 Share Posted April 30, 2020 miniatures.com is a good source.....but there are TONS of online mini shops to buy from. I always like to support the ones in my state, or at least the closest to me. Quote Link to comment Share on other sites More sharing options...
Jennifer S. Posted May 4, 2020 Author Share Posted May 4, 2020 Thank you! I never heard of wallpapering a ceiling until reading some articles today. Why is that needed, especially if you already painted them? Quote Link to comment Share on other sites More sharing options...
KathieB Posted May 4, 2020 Share Posted May 4, 2020 You might want to wallpaper a ceiling for a texture or a faux "painted" effect or if the wood surface is too rough for paint to smooth out or ... the house tells you to do it! And you want to paint/seal the ceiling before wallpapering or the natural acids in the wood will eventually leach through and turn the paper brown. Quote Link to comment Share on other sites More sharing options...
Jennifer S. Posted July 14, 2020 Author Share Posted July 14, 2020 Well, I’ve electrified the dollhouse throughout and put in ceiling fixtures. Now I’m on to wallpapering. I’ve decided to use card stock for templates and backing for the wallpaper that will be glued onto them. I want to use double-sided tape to attach the card stock to the walls, so I can remove them if necessary to get to the wires. Can any of you recommend a brand that has excellent tacky ness, is acid free, can be removed without extreme difficulty, and lasts? Quote Link to comment Share on other sites More sharing options...
KathieB Posted July 14, 2020 Share Posted July 14, 2020 4 hours ago, Jennifer S. said: Can any of you recommend a brand that has excellent tacky ness, is acid free, can be removed without extreme difficulty, and lasts? I have not tried Aileen's Tack-It Over & Over glue, but its description seems to be what you are looking for. It looks as if you would just use some dots of it well spaced, it would do the trick. If you try it, let us know how it works. Quote Link to comment Share on other sites More sharing options...
havanaholly Posted July 14, 2020 Share Posted July 14, 2020 Check your local art supply store for acid free anything. Quote Link to comment Share on other sites More sharing options...
Jennifer S. Posted July 15, 2020 Author Share Posted July 15, 2020 Thank you for your suggestions! Aileen’s tack-it over glue sounds very promising. Has nothing but excellent reviews. I’ll let you know how it works out. Quote Link to comment Share on other sites More sharing options...
Jennifer S. Posted July 23, 2020 Author Share Posted July 23, 2020 Well, I got the tack-it over glue. Looks like it’s for temporary holds and not for lasting purposes. Ideally, I’d like something that works like permanent adhesive but is also removable if needed. I keep on going back and forth on using the card stock as backing. What do you think is best? I have the added problem of putting the baseboards and crown and chair molding onto it, along with any wainscoting. So many ideas and questions! It keeps me up all night! When doing the electrical, my soldering wasn’t the best in places, so I have some bumps where I soldered that will need to get covered, which is also why I thought cardstock would be a good option. Quote Link to comment Share on other sites More sharing options...
KathieB Posted July 23, 2020 Share Posted July 23, 2020 5 hours ago, Jennifer S. said: some bumps where I soldered that will need to get covered, You might try going over the bumps with a hot soldering iron to melt them down flat and/or remove the excess or rub gently with an emery board to sand them a bit flatter Quote Link to comment Share on other sites More sharing options...
Jennifer S. Posted July 24, 2020 Author Share Posted July 24, 2020 (edited) I tried to do that, but they wouldn’t smooth out for me, so I put spackling over the bumps to get the area more uniformly smooth in certain places. I also discovered a bit late that any other brand of liquid tape other than the actual one doesn’t work and causes too many problems. The one I used at first was like plastic vs. rubber. It was all bumpy and not smooth when it dried, so that was part of the problem. What do you suggest? Cardstock or just wallpaper on the walls? The cardstock is really nice and strong. It makes a great backing (and of course, acid free). Edited July 24, 2020 by Jennifer S. Quote Link to comment Share on other sites More sharing options...
Kate Grohe Posted August 5, 2021 Share Posted August 5, 2021 Kate I have found the comments helpful but no one mentions priming the wood doll house. Do you have to prime the wood prior to installing tape wire or prime after? Have not electrified a house before. It's the S/W Country Estate House I started in 82 and have been working on the past 2 summers. 1 Quote Link to comment Share on other sites More sharing options...
jbnmini Posted August 5, 2021 Share Posted August 5, 2021 9 minutes ago, Kate Grohe said: Kate I have found the comments helpful but no one mentions priming the wood doll house. Do you have to prime the wood prior to installing tape wire or prime after? Have not electrified a house before. It's the S/W Country Estate House I started in 82 and have been working on the past 2 summers. Kate- it is always best for the very first step of construction to be to prime the wood - except in places that stain will be used on floors. 👍 Quote Link to comment Share on other sites More sharing options...
