Blondie Posted March 4, 2014 Share Posted March 4, 2014 My Maison McColl house has salmon, pink, and purple paint on it that has been sealed with something that makes it very shiny. I'm rehabbing this house, so I'll be painting over the original paint. Sanding won't work because it barely touches the shiny seal. My father told me about "seal breakers," but they scare me a bit with all of those chemicals. I'm also worried about hurting my fragile-ish wood. I may have to call someone who refinishes real life furniture to get some ideas. I used Kilz Primer in white. I put it on the frame kind of thick and then let it dry. I can scratch the primer off with my thumbnail and see the salmon still there with no scratches. Primer fail!! If I leave it and paint over it, it could all come chipping off in a few weeks and that would be NO GOOD. Any suggestions? Quote Link to comment Share on other sites More sharing options...
KathieB Posted March 4, 2014 Share Posted March 4, 2014 Try gesso as a primer. It may stick better than Kilz. Or may not. Just a suggestion. Quote Link to comment Share on other sites More sharing options...
Debra from Olde Cape Cod Posted March 4, 2014 Share Posted March 4, 2014 I was just in Lowes the other day and saw something in the turpentine section. But darn if I can't remember what it was! But it was supposed to degloss so you could apply another coat of finish without hurting the stain underneath when you're refinishing furniture. If I'm out that way today, I will take another look and write it down.... Quote Link to comment Share on other sites More sharing options...
Selkie Posted March 4, 2014 Share Posted March 4, 2014 I think Debra is on the right track. There are several products for use when you are redoing countertops that de-gloss laminate so the new paint will adhere and that has to stand up to lots of use so "sticking" is super important. My DIL has done a countertop that way and it came out very nice and hasn't chipped. Because you have paint underneath whatever the shiny stuff is, I don't think you will damage the wood. The paint should be enough of a barrier. It's not like you will be soaking it in it. Probably it's a "wear your gloves" kind of thing but I do that with lots of things. Another thought is to take one of your sections right into the paint store with you and have them take a look at it and see what they think it might be and what would be best to use. Good luck - can't wait to see how it comes out. Quote Link to comment Share on other sites More sharing options...
Sable Posted March 4, 2014 Share Posted March 4, 2014 Try alcohol. I know it can ruin furniture finish very easily. Quote Link to comment Share on other sites More sharing options...
Soapz Posted March 4, 2014 Share Posted March 4, 2014 A gel stripper to roughen the surfaces? I know there are some not so heavy duty ones (as in: not dangerous to health) - they don't work great but should do the job of stripping at least one layer. Quote Link to comment Share on other sites More sharing options...
Deb Posted March 4, 2014 Share Posted March 4, 2014 A cheap and non-toxic thought is to try using matte Mod Podge as a sealant. It has enough of a tooth that I've used it as a primer before putting wallpaper on a slick surface so it might be worth a try. Depending on what they used to make the "shiny" parts shiny, the Mod Podge might peel off too but it's worth a try, especially if you have a jar on hand already. Deb 2 Quote Link to comment Share on other sites More sharing options...
Blondie Posted March 4, 2014 Author Share Posted March 4, 2014 All of these are very good suggestions. The trim is especially shiny, so maybe I'll take a piece of that with me and go stalk a paint guy at a store. One problem I might encounter is that I read about a few of these strippers, and you're supposed to repaint within an hour. I have a rather elaborate paint scheme worked out with a bunch of different colors, so maybe I'll just have to paint all of it white real quick and then do the real paint job later. There are a LOT of pieces to strip here. I CAN DO IT! Boing boing! (Convinces self!) Quote Link to comment Share on other sites More sharing options...
Soapz Posted March 4, 2014 Share Posted March 4, 2014 There is a shellack based primer out there - Zinsser or BIN - not sure, but they stick on everything. I used it on vinyl high-gloss cabinets and it still sticks after 6 years, so that should work no matter what. It's expensive but definitely my go-to solution for crappy surfaces. Quote Link to comment Share on other sites More sharing options...
Selkie Posted March 4, 2014 Share Posted March 4, 2014 If you use the shellac based one, remember it's not water cleanup. There are several varieties out there and it's easy to mix up the water based ones with the shellac based one. Quote Link to comment Share on other sites More sharing options...
Blondie Posted March 5, 2014 Author Share Posted March 5, 2014 I just read all of your suggestions to my father, and he said we can find some of these items and give them a whirl in spring. He has a big Morton building (farm equipment building) that we can work in to have plenty of ventilation. I'm really grateful for all of your suggestions and help!! Thank you SO much! :) I'll be sure to take pix and document the whole experience for you. Quote Link to comment Share on other sites More sharing options...
havanaholly Posted March 7, 2014 Share Posted March 7, 2014 If you're working in warmer weather with open ventilation you can buy a box of disposable rubber gloves and use a chemical stripper you don't have to immediately repaint after the old surface gunk comes off, especially if your dad is helping you. Quote Link to comment Share on other sites More sharing options...
