~Sydney~ Posted September 4, 2010 Share Posted September 4, 2010 Maybe if I thin it out?I shoudl use wallpaper paste, but I won't be able to get any this weekend. Thanks in advance! Sydney Quote Link to comment Share on other sites More sharing options...
havanaholly Posted September 4, 2010 Share Posted September 4, 2010 I've used Elmer's white all-purpose glue, you need to spread it out evenly and completely cover the back of the paper. I dip my fingers into a jar of water to spread the glue across the back of the paper, which thins it some and keeps it wet long enough for a quick adjustment in positioning. I prefer to use RL wallpaper paste, but the last batch I got turns out to be "for prepasted" wallpaper only, and doesn't work worth a darn on wallpaper! I wouldn't use wood glue, since it dries a brownish-yellow. 1 Quote Link to comment Share on other sites More sharing options...
rbytsdy Posted September 4, 2010 Share Posted September 4, 2010 I've used white school glue to apply all my wallpaper (I smear it evenly on the backside with a bit of cloth, then use a clean white cloth to smooth it onto the wall), but then I use printies on cardstock. Not sure if it works just as well on "store-boughten" miniature wallpaper! Quote Link to comment Share on other sites More sharing options...
pin1056 Posted September 4, 2010 Share Posted September 4, 2010 i use tacky glue...no problems so far Quote Link to comment Share on other sites More sharing options...
Momof2Moos Posted September 4, 2010 Share Posted September 4, 2010 I use Elmers and a squeegee and it works beautifully. Smear it on evenly all the way from edge to edge, put in place, press firmly and then use something that is stiff, but not going to tear up the paper, to squeegee the glue and air out. 1 Quote Link to comment Share on other sites More sharing options...
Alamom Posted September 4, 2010 Share Posted September 4, 2010 I've used Elmer's school glue for wallpaper too. Bought up several bottles when walmart had them for 25 cents for back to school. Like everyone else said, spread evenly on back. If your using printie paper, make sure you seal the paper really good with spray sealer. Quote Link to comment Share on other sites More sharing options...
havanaholly Posted September 4, 2010 Share Posted September 4, 2010 I have a wee wooden brayer that was made for the prepasted wallpaper borders that I roll the bubbles out and flatten the paper with. Quote Link to comment Share on other sites More sharing options...
cranky Posted September 4, 2010 Share Posted September 4, 2010 i use wood glue, put a little in a container, add just a little water to thin it a little, which makes it more workable.....then i spread it on!!!!!! Quote Link to comment Share on other sites More sharing options...
havanaholly Posted September 4, 2010 Share Posted September 4, 2010 Does the wood glue not stain the paper? Quote Link to comment Share on other sites More sharing options...
cranky Posted September 5, 2010 Share Posted September 5, 2010 i haven't had a problem yet, but i seal the paper with a fixative first... Quote Link to comment Share on other sites More sharing options...
Ollie Posted November 13, 2017 Share Posted November 13, 2017 I just asked if I could use craft glue to put some wallpaper down in a closet in the bathroom...I'm never going to use it for the wall...WELL YALL..IT ACTUALLY WORKED! Just cut the size you need, turn the wallpaper over, squirter the glue, spread with your fingers r with an old credit card, actually anything plastic and flat, and put down in the area... Quote Link to comment Share on other sites More sharing options...
havanaholly Posted November 13, 2017 Share Posted November 13, 2017 Hi, Heather. I hope you will post an introduction in the Newcomers' Forum. 1 Quote Link to comment Share on other sites More sharing options...
Sable Posted November 13, 2017 Share Posted November 13, 2017 Glue is permanent. Wallpaper pasted with wallpaper paste can be removed with vinegar and water. If you think anyone would ever want to remove the paper, don’t use glue. Quote Link to comment Share on other sites More sharing options...
Ollie Posted November 13, 2017 Share Posted November 13, 2017 34 minutes ago, Ollie said: I just asked if I could use craft glue to put some wallpaper down in a closet in the bathroom...I'm never going to use it for the wall...WELL YALL..IT ACTUALLY WORKED! Just cut the size you need, turn the wallpaper over, squirt the glue, spread with ( your fingers r with an old credit card, actually anything plastic and flat) SCRATCH THAT... IT'S TOO STICKY AND I THOUGHT ABOUT IT, GET A SPONGE ( I used those $1 ones from Dollar Store ) squirter glue on the SOFT SIDE then dip in just a Lil bit of water.. ( I JUST DID THIS...after I dipped the sponge I squeezed it a little, just enough to where it looked like soap ) I then dabbed the area I was putting it down on, NOT THE WALLPAPER ITSELF and went from one corner all the way to the end AND IT STUCK... Quote Link to comment Share on other sites More sharing options...
Ollie Posted November 13, 2017 Share Posted November 13, 2017 49 minutes ago, Ollie said: I just asked if I could use craft glue to put some wallpaper down in a closet in the bathroom...I'm never going to use it for the wall...WELL YALL..IT ACTUALLY WORKED! Just cut the size you need, turn the wallpaper over, squirt the glue, spread with ( your fingers r with an old credit card, actually anything plastic and flat) SCRATCH THAT... IT'S TOO STICKY AND I THOUGHT ABOUT IT, GET A SPONGE ( I used those $1 ones from Dollar Store ) squirter glue on the SOFT SIDE then dip in just a Lil bit of water.. ( I JUST DID THIS...after I dipped the sponge I squeezed it a little, just enough to where it looked like soap ) I then dabbed the area I was putting it down on, NOT THE WALLPAPER ITSELF and went from one corner all the way to the end AND IT STUCK... Hi Havanaholly Quote Link to comment Share on other sites More sharing options...
