adraria Posted May 2, 2010 Share Posted May 2, 2010 My daughter informed me today that she would like to have a pool in her yard for her dollhouse has anyone ever tried this how would it be accomplished? Any ideas? Quote Link to comment Share on other sites More sharing options...
barbm Posted May 2, 2010 Share Posted May 2, 2010 one of the blue mushroom containers from the produce dept might work Quote Link to comment Share on other sites More sharing options...
otterine Posted May 2, 2010 Share Posted May 2, 2010 Suzy did one for her Spring Fling 09 project. Here's the link. Quote Link to comment Share on other sites More sharing options...
LLyn M. Posted May 2, 2010 Share Posted May 2, 2010 How about a large tuna can(top removed) for an above ground pool?? Hmmmmm, maybe the scale would be off?? Good luck! Quote Link to comment Share on other sites More sharing options...
Debra from Olde Cape Cod Posted May 2, 2010 Share Posted May 2, 2010 Does she want real water in it or fake water? Quote Link to comment Share on other sites More sharing options...
Suzy Posted May 2, 2010 Share Posted May 2, 2010 Mine was just painted with cork pieces around the edge for pavers. A lot of the Barbie pools are on the small side for there scale so might do well for a big 1/12th scale pool. What I found helped with the painted pool was pearlized craft paint, it gave some depth to the water and made it a little more realistic. Quote Link to comment Share on other sites More sharing options...
dainagon Posted May 2, 2010 Share Posted May 2, 2010 (edited) I have always wanted to make a pool. I figured I would get a thick piece of Styrofoam, and carve out the pool, making shallow and deep ends of course. I would put the pool in a corner of the Styrofoam sheet, and use the rest for a yard for the house to sit on. I have used this technique for ponds. If you wanted a rectangular pool, I'd start looking at baking pans in dollar stores :-) -Sarah Edited May 2, 2010 by dainagon Quote Link to comment Share on other sites More sharing options...
parisbabe Posted May 2, 2010 Share Posted May 2, 2010 it all depends if your looking at an above ground one or a below ground one....if its below i would go with Sarah. Above, i would look at the barbie idea Quote Link to comment Share on other sites More sharing options...
Audra Posted May 2, 2010 Share Posted May 2, 2010 I bought a mini pool in a store. It looks like a toddler blow up blow, but solid. Quote Link to comment Share on other sites More sharing options...
Muriel Posted May 3, 2010 Share Posted May 3, 2010 Above or below ground and with real or imagined water? Water effect can be made with resin, you could use pearlised paint underneath it to create depth. A below ground pool wouldn't need to be that deep, just have the depth effect with paint, with a thinner layer of resin over the top, and then some stones around the edge. Quote Link to comment Share on other sites More sharing options...
adraria Posted May 4, 2010 Author Share Posted May 4, 2010 Thanks for all the replies i will definitely see what i can figure out I am sure she would want it to have real water but i dont think i would be able to handle seeing real water that close to the house i spent so much time building for her so fake water it will be. I had already planned to have a pond in the yard but she wants both the pond and pool so i am thinking maybe make an inground pool which would be sunk into a patio/deck. I am trying to imagine a way that i could make to pool look like it is filled with water but still allow the dolls to pretend to be in it to swim any ideas? Quote Link to comment Share on other sites More sharing options...
janet Posted May 4, 2010 Share Posted May 4, 2010 Maybe a clear plastic cover cut to fit that she could remove when the dolls wanted to take a dip? And be sure and tell her that she can't put real water in it! Quote Link to comment Share on other sites More sharing options...
adraria Posted May 4, 2010 Author Share Posted May 4, 2010 That's a great idea I think I will try to make it have walls on the inside that look like water with an empty center so the dolls can play in it and a cover that can be removed that looks like the surface of a pool I don't know how to accomplish this yet but that's ok I have time the house is not finished yet and I have not even begun to think about putting the landscaping together yet so this project will be a while before started But any ideas are welcome for sure! Quote Link to comment Share on other sites More sharing options...
parisbabe Posted May 5, 2010 Share Posted May 5, 2010 you can always use a piece of blue plexi for thr top that can be removedThat's a great idea I think I will try to make it have walls on the inside that look like water with an empty center so the dolls can play in it and a cover that can be removed that looks like the surface of a pool I don't know how to accomplish this yet but that's ok I have time the house is not finished yet and I have not even begun to think about putting the landscaping together yet so this project will be a while before started But any ideas are welcome for sure! Quote Link to comment Share on other sites More sharing options...
butlerestates Posted May 10, 2010 Share Posted May 10, 2010 I just went to the pet store and saw a neat idea for a pool. THey have little pools that looklike ponds for reptiles and other semi-aquatic animals. THe one I saw was bean shaped and had steps at one end. It would make a really cool inground pool. Quote Link to comment Share on other sites More sharing options...
Audra Posted May 10, 2010 Share Posted May 10, 2010 hmmm...I might have to check that out! Quote Link to comment Share on other sites More sharing options...
adraria Posted May 11, 2010 Author Share Posted May 11, 2010 i never thought of that i will have to have look Quote Link to comment Share on other sites More sharing options...
Debra from Olde Cape Cod Posted May 11, 2010 Share Posted May 11, 2010 That sounds like a great idea! Quote Link to comment Share on other sites More sharing options...
pdlnpeabody Posted May 12, 2010 Share Posted May 12, 2010 Sara, You read my mind! I would start with non-condensed styrofoam, carve out the pool shape, only shallower, and add a layer of spackle. Sand to a smooth surface, airbrush a light blue to medium blue fade (for the deep end) and add resin. I always use at least 3/8" styrofoam for my yards, so I would only have to make it an extra layer or two thicker for a pool. Quote Link to comment Share on other sites More sharing options...
dainagon Posted May 12, 2010 Share Posted May 12, 2010 I thought of resin, but would it eat the styrofoam? Or would the spackle protect it? I have used clear caulking for water on styrofoam, but it would take forever to fill a pool with it. Now I wanna start fiddling around with stuff and seeing what works! :-) -Sarah Quote Link to comment Share on other sites More sharing options...
pdlnpeabody Posted May 13, 2010 Share Posted May 13, 2010 I thought of resin, but would it eat the styrofoam? Or would the spackle protect it? I have used clear caulking for water on styrofoam, but it would take forever to fill a pool with it. Now I wanna start fiddling around with stuff and seeing what works! :-) -Sarah I wouldn't use resin (it requires a very toxic, corrosive catalyst) but 2 part epoxy would work perfectly. It won't dissolve the styrofoam, but you do have to mix it thoroughly before pouring it. Quote Link to comment Share on other sites More sharing options...
