dyonis Posted August 22, 2008 Share Posted August 22, 2008 Ok, I'm doing my first dollhouse,The Orchard and I don't recall anywhere in the instructions to wallpaper or paint the house inside. My problem is now, I have the house put together, and I still don't have it wallpapered or painted. My question is, do I need to tear half this house apart to do this, or can it be done while put together? windows are already taped over for the painting. Dyonis Quote Link to comment Share on other sites More sharing options...
PATBIDLACK Posted August 22, 2008 Share Posted August 22, 2008 I find it easier to paper and paint before the house is finished. However there are sometimes when you have to do it afterwards and yes it is possible. Quote Link to comment Share on other sites More sharing options...
dyonis Posted August 22, 2008 Author Share Posted August 22, 2008 Thanks, I was going to take the roof off and do the papering, but I think I'll leave it on, since I hot glued it (I know it's a nono). so, I'll wait til that falls apart then redo the roof, on the inside, I'll just paint carefully, and put a little wallpaper at the alcoves, maybe. It's not like I have to have it finished by yesterday, thank god. Quote Link to comment Share on other sites More sharing options...
justmesue Posted August 22, 2008 Share Posted August 22, 2008 I did my Orchid interior after it was assembled on purpose. It's very doable in this particular house. The only hitch will be, if you have already put the stairs in, it makes things just a little tricky on that wall. Good luck, and have fun! Quote Link to comment Share on other sites More sharing options...
Wolfie Posted August 22, 2008 Share Posted August 22, 2008 This is not impossible to do after it is put together......just a little trickier! Make yourself some templates and then cut the paper to fit, and either glue to cardstock or on the wall directly. Please prime first with plain white paint all of the areas not to be stained....... There are wonderful tutorials and blogs on here on how to finish your dollhouse! Welcome to the forum! Quote Link to comment Share on other sites More sharing options...
havanaholly Posted August 22, 2008 Share Posted August 22, 2008 In my Orchid building blog I believe I mentioned that I decorated upstairs as I built, then got primer drips running all over the paper and had to remove it & start over after it was together. I didn't even finish the downstairs until after it was together because I realized I had left the materials I had planned to use at home. One useful thing this hobby teaches you is to improvise... Quote Link to comment Share on other sites More sharing options...
chesterfieldzoo Posted August 22, 2008 Share Posted August 22, 2008 It's not that hard to do after the build. Just take your time. The house is small enough to flip around upside down and on its side so you can see into the corners. I would reinforce the seams with wood glue before painting though. Or small nails. Quote Link to comment Share on other sites More sharing options...
Debra from Olde Cape Cod Posted August 23, 2008 Share Posted August 23, 2008 And when you electrify a house, you kinda have to do the wallpapering and painting after it's assembled. Quote Link to comment Share on other sites More sharing options...
Lisa R. Posted August 24, 2008 Share Posted August 24, 2008 I always paper and paint after the house is finished. It is a bit tricky but sometimes the house won't talk to you until it is assembled. Lisa R. Quote Link to comment Share on other sites More sharing options...
wenlaine Posted August 24, 2008 Share Posted August 24, 2008 I always have my houses assembled before doing any decorating. I leave the staircases out until it's time to decorate. I never know what room will be what until I see the dollhouse built. Quote Link to comment Share on other sites More sharing options...
havanaholly Posted August 25, 2008 Share Posted August 25, 2008 Usually the dh will tell me what it wants whilst it's in dry-fit, before assembling, and lately they start in before I ever get the box opened, sometimes before I even get the box! Quote Link to comment Share on other sites More sharing options...
dyonis Posted August 30, 2008 Author Share Posted August 30, 2008 ok, here is the first picture of my dollhouse, if you look closely, you can see many mistakes. oh well, I'm sure I can hide alot of these. Quote Link to comment Share on other sites More sharing options...
sparklepuppies Posted August 30, 2008 Share Posted August 30, 2008 Looks great to me! Good job! Will you keep it that color? I like the different wood colors you have so far. Quote Link to comment Share on other sites More sharing options...
dyonis Posted August 30, 2008 Author Share Posted August 30, 2008 No, I already primered the outside. I have been staring at it for 3 days now, and I'm thinking of a light cream color, with cranberry and hunter green trim. I was thinking about maybe a little ivy on the side of it. and maybe some planters in the windows. Oh, the possibilities. If I keep this up, I'll never get the first house done. Quote Link to comment Share on other sites More sharing options...
Missymew Posted August 30, 2008 Share Posted August 30, 2008 And when you electrify a house, you kinda have to do the wallpapering and painting after it's assembled. Not so. I always paint and paper before I put the house together. I plan the routes for my electrical wires beforehand, and then make templates on those walls/ceilings or floors. On those particular walls, I paint or wallpaper the templates. After wallpapering/painting the non-electrical walls, I put the house together. Then I run the electrical, and then use double sided tape to put the template walls/floors/ceilings on. It comes together so easily that way. I don't have to do any bending, reaching, stretching. Then I install mouldings and baseboards. For me, this works the best. -Susanne Quote Link to comment Share on other sites More sharing options...
havanaholly Posted September 1, 2008 Share Posted September 1, 2008 No, I already primered the outside. I have been staring at it for 3 days now, and I'm thinking of a light cream color, with cranberry and hunter green trim. I was thinking about maybe a little ivy on the side of it. and maybe some planters in the windows. Oh, the possibilities. If I keep this up, I'll never get the first house done. Your proposed color scheme sounds totally lovely. You don't have to "finish" the first house before you begin to build another! Quote Link to comment Share on other sites More sharing options...
dyonis Posted September 1, 2008 Author Share Posted September 1, 2008 oh, see that's just tempting me into getting in trouble with the bank book. lol. I'm already ebaying furniture, which fiance thinks is crazy. Some people just don't understand the passion. Quote Link to comment Share on other sites More sharing options...
andrea_burgess Posted September 17, 2008 Share Posted September 17, 2008 I just finished my first dollhouse (The Coventry Cottage) and I decorated after I was done assembling. I had a really hard time envisioning what each room was until it was all put together. I didn't have any real problems, except in one room that had 3 walls, but I still managed to make it work. Good luck! -andrea Quote Link to comment Share on other sites More sharing options...
