Snowbird66 Posted February 24, 2019 Share Posted February 24, 2019 I think I just blew my transformer. All was going well until I tried to install a new fixture. Now nothing works! Is there a way to reset my transformer...Model CK 1009 B? I'm new at this and getting frustrated! I surely could use some advice! Quote Link to comment Share on other sites More sharing options...
Mid-life madness Posted February 24, 2019 Share Posted February 24, 2019 Try removing that last fixture you installed..it could have shorted something out. Then test along the wire to see if you are gerring power. Also make sure the junction splice is inserted securely. ~~~Good Luck~~~~ Quote Link to comment Share on other sites More sharing options...
Sable Posted February 24, 2019 Share Posted February 24, 2019 How many bulbs are you using with that transformer? Did you see smoke or hear a pop? I did that when I placed a hammer down on two tapewire connections while it was plugged in. That’s when I learned to always put scotch tape on my connections. Quote Link to comment Share on other sites More sharing options...
Sable Posted February 24, 2019 Share Posted February 24, 2019 Do you have an electrical probe to test the transformer? Touch it to the two screws and see if it lights up. Quote Link to comment Share on other sites More sharing options...
