Very first dollhouse - Advice please
Hello everyone.  I just bought my first dollhouse (The Orchid) and I'm excited but rather nervous to start it.  I want to make sure I do everything right, so I'm asking for your tips & tricks for starting out.  I've looked around the site a bit, but there's so many posts here it's kind of over-whelming.  Any advice would be greatly appreciated.
Liz, I also am working on an Orchid. It’s a really cute little house. I elected to omit the stairs to give me more space, so I cut a smal piece of wood and glued it in the space. In my kit there was a piece of trim inside the stair hole that I want to use, so I couldn’t just not punch that piece out. But that is an option that is the easiest way to fill in the hole. If you are interested in doing this, search my posts and you’ll find that thread.
If you search on the term Orchid and look at images, you can find a lot of members’ projects that can give you some ideas. The Orchid makes a great haunted house if you’re interested in that. The one slightly tricky part about the Orchid is the windows. The house frame forms part of the window frame...it’s an illusion. So you need to paint the part of the house frame at the windows the same color as you intend to paint the windows. There is another recent post about these windows that I’m sure someone else will link here. I’m working from a mobile device and it’s not as quick at searching. THe directions have you installing the windows before you assemble the house but I’ve chosen not to do that. Some people like to wallpaper each piece before assembling but I don’t want any gaps at the wall connections so I have assembled it first and will finish the walls later.
there is so much flexibility with dollhouses, I suggest you read lots of posts to get different ideas so you can do what you want. Everything you do will be a learning experience, so be prepared!
Good luck and have fun!
The Orchid is a great house for beginners.  I built one some time ago.  First, do NOT use hot glue.  Wood glue or Aleenes Fast Grab Tacky glue work great.  Also, make sure that you have a plan and always dry fit parts before glueing. Work on a level sturdy table and have clamps, clothes pins, and tape nearby.But the most  important thing is to have fun with it.  To me, its like a puzzle that gets more and more detailed as you go. Be patient with it and yourself.
Liz, if you click on the "Blogs" button at the upper left of every page you will find TWO Team building blogs for the Orchid, since it's such a popular little house; one for the regular building team and one for whatever members wanted to see what they could do with it.  Also at one time the Orchid kit was die cut out of a white plastic (sterlite?) and some of us had an interesting time building that one(regular plastic model cement didn't faze that stuff; E6000 conquered it) and there's a section of the gallery devoted to it, plus for some reason I wound up with two albums of my version.
Hi Liz. Your goal is a lofty one, and i understand you want to be pleased with the end result. However, keep in mind that there is really no right way to build a dollhouse. If you ask a question, you will receive answers that reflect a variety of ways to tackle a challenge. The one that seems most practical to you is the one to go with. The best advice will keep you from doing something that isn't going to work well. Yet keep in mind that there is almost no error that can't be fixed.
Have fun with the build and decorating. Don't be afraid to experiment. Try not to obsess over perfection. My mantra is "smoke and mirrors" -- if it ends up looking right, it IS right, however you got there. :D
  • Similar Content
    • By MC
      I'm now on to my third dollhouse, and unlike the first two which were purchased kits, this doll house is a rescue!!  Found on a street curb, it was really in pretty good shape. The original builder did a good job constructing the house; the shingles are a lesson in perfection; the painting and wallpaper show a better than average understanding of how to handle these tasks; floorings were in good shape and installed with double sided tape.  Yes, there are a few loose shingles, the door is broken along with the porch.  Biggest problem is the outside wall are dado cuts to mimic siding and the builder reversed the front and glued the siding side inside rather than outside.  That will be easily remedied with Greenleaf siding strips.  This will soon be the Farmhouse I envision.
      But I desperately want to replace the windows.  The large front windows are a bit smaller than standard size--I'll enlarge opening to accept new windows.  However, the dormer windows are rectangular rather than square and an irregular size.  I have not been able to identify the dollhouse, so there is no chance of finding manufacturer to see if there is a more current window style available.  I am now faced with going where I haven't gone before and building my own windows.
      Any suggestions or words of advice out there?
    • By Lou
      I purchased an almost completely built Glencroft dollhouse at an estate sale. The only things left to do are the windows and doors. No directions came with the house. I have looked at a lot of pictures online but I simply can't figure out how to do the windows. Can anyone help me? Thanks in advance.
    • By Samusa
      Here is a picture of the clip on earring back light bulb & shade holder for Miranda (SewMini).
      Jewelry pin through the middle hole. Light bulb wire through any of the others.  The shade fits snugly onto the earring back, holding it in place.
      The holes in the earring back allow light to come out of the bottom of the lamp as well as the top.
    • By Mary S.
      Bet y'all thought I left. Oh no, been busy, busy busy. Work on real house (hired someone to do it, but I still had to move "stuff", so got rid of a lot of junk; this took 2 weeks. The Orchid is not really finished, still needs a few bits of trim, but must be 99.8% done. Working on furniture now. What I have will not fit in the kitchen, don't know for sure how to fix that. Will make the bay window a seat for lounging as well as seating for dining. Probably 2 small corner cabinets? for dishes etc. Any ideas/suggestions for decoration, furniture, or anything else will be greatly appreciated. I made a door knob for the front door, but will have to make another, 'cause now I cannot find the first one. Working on Kris C.'s shabby chic bed right now, then a wardrobe, night stand and dressing table, a comfortable chair and ottoman for the gable, with lamp and bookcase. I've really missed everyone and am glad to be back. Next up will be the remake of the doll's wardrobe into something pretty, probably a dressmakers shop.In the closet (now that there is room) is the Lafayette for later.
      It is also time to sew for back to school. Here is my lineup: girls Sara 17, Steff 15, Renee 14, Kaelie 8, Alana 5. Boys Jeremy 15, Andrew 6. The babies: Ansley 3, Petra 1,  Aiden 1, Callie 2 and twin girls 5 months. The oldest graduated last spring. Some of these are foster kids, but I am grandma and claim them all while they are with us (not mine, my daughter).
