blue_moon992 Posted October 29, 2006 Share Posted October 29, 2006 How do you fix this....... The top of the roof where the shingles meet is really not pretty lol. I don't really have any trim work that would fit there and look right..... Hm. Any thoughts? But I got the shingles up!! Horray!! Thanks!! Quote Link to comment Share on other sites More sharing options...
Minis On The Edge Posted October 29, 2006 Share Posted October 29, 2006 I use corner trim to give a clean edge on my roof lines. I'll show pics in one sec... Here is one link: http://www.greenleafdollhouses.com/forum/i...si&img=4604 Here is another one: http://www.greenleafdollhouses.com/forum/i...id=7&cat=14 Quote Link to comment Share on other sites More sharing options...
JaimieMarvon Posted October 29, 2006 Share Posted October 29, 2006 FleckStone spray paint. It will make your shingles look like real shingles. I did it on my Garfield roof, but on the wood, no shingles. Check out my pics if you are interested. Good luck! Quote Link to comment Share on other sites More sharing options...
Color Me Holly Posted October 29, 2006 Share Posted October 29, 2006 I haven't gotten this far, yet. I plan to bend the shingles over the peak like its done on real houses. The shingles curl when wet. I will use silicon caulk to put the cap on and tape this down with lots of tape and let it dry. Quote Link to comment Share on other sites More sharing options...
blue_moon992 Posted October 29, 2006 Author Share Posted October 29, 2006 I use corner trim to give a clean edge on my roof lines. I'll show pics in one sec... That is prolly what I'll end up doing. I smushed the very top row down as far as i could get it and that is still what I ended up with lol. It's not horrible, but, it can be better. Think I'll stain them in a bit... Thanks Quote Link to comment Share on other sites More sharing options...
Charlene Posted October 29, 2006 Share Posted October 29, 2006 You can use peak trim, corner trim, or edge trim and you can also use half-shingles at the peak...those are laid perpendicular to the roof shingles with the two half shingles meeting at the peak. Any of these will give your roof a nice, finished look. Quote Link to comment Share on other sites More sharing options...
KathieB Posted October 29, 2006 Share Posted October 29, 2006 You can also use scissors to trim the uneven shingles at the roof line. That will clean it up some, even without adding trim. Quote Link to comment Share on other sites More sharing options...
havanaholly Posted October 30, 2006 Share Posted October 30, 2006 I use split shingles laid along the roofline, I've also used split siding strips. With sandpaper shingles & construction paper slates I used strips of the same material and with the corrugated "tin" roof I used a strip of aluminum foil. Quote Link to comment Share on other sites More sharing options...
