kat57 Posted December 6, 2013 Share Posted December 6, 2013 Beautiful and creative! I love it! Quote Link to comment Share on other sites More sharing options...
Dalesq Posted December 7, 2013 Share Posted December 7, 2013 I'm getting inspired! I want to make half scale lights with LEDs. Hmm..... Quote Link to comment Share on other sites More sharing options...
moonberry Posted December 7, 2013 Share Posted December 7, 2013 Judi - you are officially a lighting genius! I think I actually have a few of those same ornaments - found them in the Hindi section when it was Diwali and they were hanging at the bottom of a long strand of smaller plastic crystals (they hang them from doorways, trees etc). I did not know you could drill into them - this is a REVELATION I always thought the acrylic would crack. What kind of drill did you use? I just bought a set of small finger drills from Hobby Builders Supply (they should be arriving next week) so that I can drill really small holes in the floor of my Arthur to hang the downstairs lights from jewelry head pins. I wonder if they are strong enough to drill carefully into acrylic. I may get blisters on my fingers, but hey, its for Art! 1 Quote Link to comment Share on other sites More sharing options...
WyckedWood Posted December 7, 2013 Share Posted December 7, 2013 I love your chandelier! beautiful work. Quote Link to comment Share on other sites More sharing options...
havanaholly Posted December 7, 2013 Share Posted December 7, 2013 Lene, clamp the heck out of your crystal before drilling it. You might be happier if you could get your paws on a used dental drill and bits, since they run at much faster rpms and drill teeth without cracking them. Quote Link to comment Share on other sites More sharing options...
mamathistle Posted December 7, 2013 Author Share Posted December 7, 2013 Judi - you are officially a lighting genius! I think I actually have a few of those same ornaments - found them in the Hindi section when it was Diwali and they were hanging at the bottom of a long strand of smaller plastic crystals (they hang them from doorways, trees etc). I did not know you could drill into them - this is a REVELATION I always thought the acrylic would crack. What kind of drill did you use? I just bought a set of small finger drills from Hobby Builders Supply (they should be arriving next week) so that I can drill really small holes in the floor of my Arthur to hang the downstairs lights from jewelry head pins. I wonder if they are strong enough to drill carefully into acrylic. I may get blisters on my fingers, but hey, its for Art! Lene I used my Dremel... first I ground off the point on the top down about 1/4 inch then used a small drill bit to start the hole..then used router bit # 640 to make the hole larger and deeper you have to go slow ad not put to much pressure on the drill (crystal will get hot and melt).... l when I had it deep enough I took # 144 cutter bit which is for soft materials to finish the hole in the middle...go slow because the Acrylic will melt (ask how I know) ... then I drilled 5 holes around the bottom with a 3/64th drill bit .. I used 20guage wire for the arms but when I do the next one I think I will use one size larger .. I then put 3 led's in it..if you want less led's then you don't have to drill the center hole as big as what I did.... just big enough for the light to fit ...but I wanted it real bright so I used 3 and because they don't get hot they are safe.. after soldering on the wires and coating them ..(you could use shrink tubes) I glued a bead cap and a wire loop on top for a chain...hope this helps if you have any other questions just ask !!! Judi 1 Quote Link to comment Share on other sites More sharing options...
mamathistle Posted December 7, 2013 Author Share Posted December 7, 2013 Lene, clamp the heck out of your crystal before drilling it. You might be happier if you could get your paws on a used dental drill and bits, since they run at much faster rpms and drill teeth without cracking them. Holly .....your right they are hard to clamp so I got a block of wood and had DH cut a hole the size of the large acrylic crystal as I want to make more light for the Garfield..I think he use one of those things you put on your drill that cuts holes... 1 Quote Link to comment Share on other sites More sharing options...
