peggyquade Posted September 23, 2006 Share Posted September 23, 2006 Attached is a picture of the last eve on my Linfield and the decor that is supposed to be here. As you can see, there is a huge gap on either side of the decor and the roof. What would you do if this was your project? I have some scrap wood. I could carefully cut out two pieces to fit the gaps, glue them together, wood putty the gaps, sand and then paint them to look like they are all one piece. A lot of work. Any ideas? Quote Link to comment Share on other sites More sharing options...
nuttiwebgal Posted September 23, 2006 Share Posted September 23, 2006 clamps I use clamps on the trim areas let the glue set up before removing them. I use the clamps that look like guns with a trigger...you can make them smaller slowly till its where it needs to be. also make sure you are using the right trim in the right area the Westville had 3 peaks with 3 different size trim for them. nutti Quote Link to comment Share on other sites More sharing options...
wenlaine Posted September 23, 2006 Share Posted September 23, 2006 Also, you may try moving it up and to the outside of the roof edge. Not sure that would help but worth a try. Quote Link to comment Share on other sites More sharing options...
Charlene Posted September 23, 2006 Share Posted September 23, 2006 I'm with Nutti - clamp it! Should be able to move the eave enough to meet the trim. Quote Link to comment Share on other sites More sharing options...
wenlaine Posted September 23, 2006 Share Posted September 23, 2006 I'm sorry, just disregard that message I wrote. Don't know what I was thinking, the only excuse I can give is "it's early". Quote Link to comment Share on other sites More sharing options...
LPCullen Posted September 23, 2006 Share Posted September 23, 2006 Actually Wendy, I think you may be on to something there. I can't see all of the house in that picture, or what I need to see. I need to see the peak on the roof and the sides all the way where the trim meets the sides of the roof line. Also, is this piece of trim one piece or two pieces? Quote Link to comment Share on other sites More sharing options...
KathieB Posted September 23, 2006 Share Posted September 23, 2006 From what I can see in the picture, I think I'd consider nutti's advice and see if there is another gable that this goes in. It appears to be too far off the correct angle to belong here. If this is the right piece, right place, I'd consider cutting it up the middle, spreading it to fit, then filling in the gap, smoothing, and painting. Less work than filling gaps on both sides. Quote Link to comment Share on other sites More sharing options...
Minis On The Edge Posted September 23, 2006 Share Posted September 23, 2006 I had to clamp this house everytime I built it. I had the same problem with the Heritage too. I love the color scheme too by the way :lol: Quote Link to comment Share on other sites More sharing options...
heidiiiii Posted September 23, 2006 Share Posted September 23, 2006 If all else fails, center it in the eave. Then use pieces of balsa strips and glue to cover gaps.. Does that make sense? It is not early but dh let me sleep until 10:30am so I am just waking up. Quote Link to comment Share on other sites More sharing options...
peggyquade Posted September 23, 2006 Author Share Posted September 23, 2006 All great advice, folks! Thanks for all your ideas. I did make sure it was the right trim for the right eve. The others fit so beautifully that I was really stumped with this one. Still not sure what I will do but I'll post a picture when I figure it out! Quote Link to comment Share on other sites More sharing options...
peggyquade Posted September 28, 2006 Author Share Posted September 28, 2006 I finally got around to trying to fix this eve vergeboard gap problem. I tried the clamps but there was absolutley no give in either the vergeboard or the roof line so I took someone's suggestion and cut right down the middle of the vergeboard. It wasn't as hard to cut as I thought it would be...you know, that cheap, thin plywood stuff. I taped each half in place against the roof line so I could trace a pattern of the gap. Then I cut a piece about that shape and size and glued it to the back of the vergeboard. When that was dry, I filled the gap with Paper Clay and let it dry, then painted it. Here's a picture of the vergeboard with the Paper Clay drying. Didn't turn out too bad. You don't want to compare it to the other vergeboards because that center part is way wider on this one than the others but you don't see them side by side so it's ok. Thanks for all your suggestions! Quote Link to comment Share on other sites More sharing options...
KathieB Posted September 28, 2006 Share Posted September 28, 2006 Way to go, Peggi ... looks good. Quote Link to comment Share on other sites More sharing options...
wenlaine Posted September 28, 2006 Share Posted September 28, 2006 That turned out great, glad you found the solution. Quote Link to comment Share on other sites More sharing options...
Minis On The Edge Posted September 28, 2006 Share Posted September 28, 2006 PERFECT solution!! in the end, who'll know you had to do that? I love the colors so much too! Quote Link to comment Share on other sites More sharing options...
Anna Posted September 28, 2006 Share Posted September 28, 2006 Such a great idea to try out and it worked wonders! Great job! Hugs Quote Link to comment Share on other sites More sharing options...
