Adallae Posted August 7, 2006 Share Posted August 7, 2006 Hello all, I've seen some great pictures of stained glass windows in the gallery. What type of paint works best on plastic to minimize smudges, fading, chiping, etc? I'd like to stain some of the windows in my Glencroft, and maybe create a unique set of china using the plain white plastic plates I found at HBS. Thanks for your help! Quote Link to comment Share on other sites More sharing options...
Charlene Posted August 7, 2006 Share Posted August 7, 2006 I've had good results with Gallery Glass paint (it's the kind you use for suncatchers) it becomes permanent after so many hours (I think 24). I've also printed the 'stained glass' on transparencies from my inkjet with good results. But others may have other ideas. Handpainted china sounds wonderful...wish I was that talented :o Quote Link to comment Share on other sites More sharing options...
Minis On The Edge Posted August 7, 2006 Share Posted August 7, 2006 Also, I have used tarnsparency film and added just clear nail polish on the "rough" side to help "set" the ink. It works well, I have some on one project that I have had for 4 years now. :o Quote Link to comment Share on other sites More sharing options...
Charlene Posted August 7, 2006 Share Posted August 7, 2006 added just clear nail polish on the "rough" side to help "set" the ink. :lol: What a great tip -- must try that the next time I print one. Thanks! :o Quote Link to comment Share on other sites More sharing options...
Minis On The Edge Posted August 7, 2006 Share Posted August 7, 2006 No problem :o another thing is that Rik taught us to use pointy Sharpie permenant markers to create the "stained window" effect. I did it on my Dungeon though you can hardley tell from these pictures: Quote Link to comment Share on other sites More sharing options...
MiniMadWoman Posted August 7, 2006 Share Posted August 7, 2006 I've used Gallery Glass too with much success. The nice thing about it too, if you don't like what you've done after it's dry, you can peel it off! :o Quote Link to comment Share on other sites More sharing options...
darrellandmelissa Posted August 7, 2006 Share Posted August 7, 2006 I have printed mine on trasnperancies. Melissa Quote Link to comment Share on other sites More sharing options...
havanaholly Posted August 7, 2006 Share Posted August 7, 2006 As I blogged when I made a "stained glass" window for the Arthur, I mixed a touch of acrylic paint with extender medium until it was diluted like watercolor and painted the design with it, I used black acrylic paint straight from the tube and applied it with a small "spotter" brush. So far the window still looks good. The clear nail polish is very good to get paint to adhere to the Chrysnbon polystyrene, I use primer but I haven't painted plates yet. The nail polish serves the same purpose, giving a "tooth" for the paint to adhere to. Quote Link to comment Share on other sites More sharing options...
doogster Posted August 7, 2006 Share Posted August 7, 2006 Actually there's no real answer to your question, there are so many types of plastic, and all take different paints differently. The windows of Greenleaf houses are acetate, so a marker (like a Sharpie) is prolly your best bet, as paint prolly won't stick. If you want to paint, I'd suggest replacing the windows you want to stain with clear styrene, then use clear model paint (transparent). I think that would give you a much better look. You can buy clear styrene sheets at WalMart in the craft section. Quote Link to comment Share on other sites More sharing options...
Minis On The Edge Posted August 7, 2006 Share Posted August 7, 2006 want to stain with clear styrene, then use clear model paint (transparent). I think that would give you a much better look. You can buy clear styrene sheets at WalMart in the craft section. Great idea Doogster! Now I am gonna try that way too. :o Quote Link to comment Share on other sites More sharing options...
heidiiiii Posted August 7, 2006 Share Posted August 7, 2006 I have used gallery glass for years. I have had no problems with it. You can also get liquid leading from the same maker. A tip with the liquid lead: You can make lines on waxed paper, then let them dry, then peel them off and stick them on the glass or plastic. That way you can cut them to the sizes you want and not get a nervous tick from trying to make it perfect. Toothpicks are your friend! :o Use them to spread you gallery glass out to the edges without using too much and having it run over your lines. Also toothpicks are good for popping any bubbles that form. You should let your masterpiece dry overnight b4 even touching it. Especially in this humid weather it can take awhile to completely set and you dont want a fingerprint in your window. Quote Link to comment Share on other sites More sharing options...
Adallae Posted August 7, 2006 Author Share Posted August 7, 2006 Thanks everyone for your help! I'll try the gallery glass and printed transparencies first, and I'll post pictures of my attempts! Quote Link to comment Share on other sites More sharing options...
