grazhina Posted June 15, 2006 Share Posted June 15, 2006 Has anyone used drywall compound on styrofoam or other foamboard? I was thinking of trying it to build up and fill in small gaps in the Nuthouse exterior, then maybe use it for a textured coating. I dumped out the papier mache I started. I was standing there, trying to declump the paper that had mashed into little balls and thought....nyeh.....there's got to be something better than this. Quote Link to comment Share on other sites More sharing options...
mbrown Posted June 15, 2006 Share Posted June 15, 2006 Well, I have never used drywall compound, but I have used papier mache before. And I have found that wall paper paste works best for papier mache. What you do is mix up the wall paper paste and then take strips of paper and slide it through or dip it in the paste. That way it doesn't clump into balls. Then after it is on whatever you are putting it on, you can go back over it with a paint brush with paste on it to seal it even more. And the wall paper paste is better to use than conventional methods because it won't mold. This doesn't really answer your question, but I hope it helps anyway!! Quote Link to comment Share on other sites More sharing options...
havanaholly Posted June 15, 2006 Share Posted June 15, 2006 I used spackle on foamboard. I prime the foamboard (both sides) before whatever else I put on it (paint, wallpaper, spackle, siding, etc. & etc.) Quote Link to comment Share on other sites More sharing options...
darrellandmelissa Posted June 15, 2006 Share Posted June 15, 2006 I have had good sucess with drywall compound on foam board. Melissa Quote Link to comment Share on other sites More sharing options...
Minis On The Edge Posted June 15, 2006 Share Posted June 15, 2006 I alos have had good success with the drywall compound on the foam board. It will work great! Quote Link to comment Share on other sites More sharing options...
grazhina Posted June 15, 2006 Author Share Posted June 15, 2006 Oakie doakie, thank you all! Now I wonder if I still have that container of stuff? Hmmmm I wonder if it's still good? Haven't used it in a while. how much you want to bet it's dried out and I have to go to the hardware store?...go here, go there.....clean the house, do the laundry....spray ant spray cause the stuff I sprayed 2 weeks ago apparently washed away or something cause I found carpenter ants crawling into the house again under a corner board.... Oh well.... Quote Link to comment Share on other sites More sharing options...
doogster Posted June 16, 2006 Share Posted June 16, 2006 I'd say using water based compound should be safe. In Canada I could get Elmer's Light Acrylic Drywall mud, or spackle. Never seen it here in the US, though you can get latex compound. As for foam versus foam board, I'd say they'll behave completely differently. Why? The paper on the foam board, or card or whatever it is. You can use super glue on paper, try it on raw foam. Quote Link to comment Share on other sites More sharing options...
LisaN Posted June 16, 2006 Share Posted June 16, 2006 I have used drywall mud on foamcore, and foam insulation. Works just fine--I created my fireplace how to in Jan. issue of AM with foam insulation, foamcore, and the fireplace is completely made of drywall mud, spread with a palette knife, and cake decorating bag. You can see a good picture of it in my blog. http://yardsaledollhousestory.blogspot.com Let it 'set up' a bit if you are doing any intricate decorative work. It should look great. If you need to age it, use Weathered Wood crackle--I used that on the siding of Minnie's Lil Scapbook store and it looked great. Quote Link to comment Share on other sites More sharing options...
Lony Posted June 17, 2006 Share Posted June 17, 2006 I never thought of using drywall compound and cake decorating tips....Evil laugh. What a superwonderfulfantablous idea!! Your brilliant!!! Quote Link to comment Share on other sites More sharing options...
Ed_Cal Posted June 18, 2006 Share Posted June 18, 2006 I have used strips of strofoam insulating board white glued and pinned together to build mountains over the shell of styrofoam strips I used either drywall compound or "Durhams rock hard water putty" AThat stuf is great holds its shape well easy to work and very fine texture Ed Quote Link to comment Share on other sites More sharing options...
fairymom Posted June 18, 2006 Share Posted June 18, 2006 I never thought of using drywall compound and cake decorating tips....Evil laugh. What a superwonderfulfantablous idea!! Your brilliant!!! I made a gingerbread house for Christmas last year for a family of teddy bears and to "frost" the roof and seams i used fast-n-final lightweight spackle watered down just a bit. i put it into the plastic icing baggies and used cake decorating tips. it worked very well! it was a little messy until i got the hang of it. you can see it on my webshot's page under Bearybread Lane if you like. but yes, it was super easy and came out great! you do have to seal it though, i used a clear varnish. good luck! www.webshots.com/user/Fairimom Quote Link to comment Share on other sites More sharing options...
