Tess11 2 Posted July 17, 2008 Share Posted July 17, 2008 I feel really silly, but I am missing some key part to using the sanding drum with my rotary tool. My tool is actually a Kawasaki brand, but all of the Dremel attachments work with it so I'm assuming if you use a Dremel you know what I'm talking about here. My issue is that the sanding drums don't stay on the bit. I slide it on the bit, tighten the little screw at the end, and when I turn it on and start sanding, the round sandpaper part flies away. It's kind of funny, really, but one of the main things I wanted this tool for was sanding and the bit without he sandpaper just doesn't work so well. :lol: I'm hoping I'm just doing something wrong, or missing a piece that holds in on, or something! I am slightly tool challenged but I manage pretty well. I'm hoping maybe one of you knows what I'm talking about. Quote Link to post Share on other sites
grynche 17 Posted July 17, 2008 Share Posted July 17, 2008 Do you mean the sanding paper thingie won't stay on the rubber thingie and launches itself into space when you sand? My Dremel-knock-off does the same thing. I wedge a small bit of paper between the sanding drum and the wheel and that helps, some. Mostly I sand towards myself in small sections, lifting the sanding drum off the wood and then down again, sorta up and down motion. Those little suckers can really fly. Bounce, too. Quote Link to post Share on other sites
Tess11 2 Posted July 17, 2008 Author Share Posted July 17, 2008 Do you mean the sanding paper thingie won't stay on the rubber thingie and launches itself into space when you sand? My Dremel-knock-off does the same thing. I wedge a small bit of paper between the sanding drum and the wheel and that helps, some. Mostly I sand towards myself in small sections, lifting the sanding drum off the wood and then down again, sorta up and down motion. Those little suckers can really fly. Bounce, too. Yep, that's exactly it. It's the most annoying thing! The dog and the kids know to stay away when I've got that tool out for fear of flying objects! Thanks for the tip. Quote Link to post Share on other sites
Esther 39 Posted July 18, 2008 Share Posted July 18, 2008 I've got a Dremel brand. I've never had that problem, unless I didn't turn the screw at the end enough. Quote Link to post Share on other sites
Intrinsicat 55 Posted July 18, 2008 Share Posted July 18, 2008 I've got the el-cheapo Wal-Mart $10 special, but surprisingly, the attachments have all worked really well - the rubber drum really fits tightly to those sanding drums (thank goodness, because I use those more than anything else....) Quote Link to post Share on other sites
havanaholly 11,102 Posted July 18, 2008 Share Posted July 18, 2008 When you crank down on the screw it compresses the rubber drum causing it to squeeze outward against the interior of the cardboard sanding tube. I occasionally had the "creeping tube" until I figured to tighten the srew on the end. Quote Link to post Share on other sites
Tess11 2 Posted July 18, 2008 Author Share Posted July 18, 2008 When you crank down on the screw it compresses the rubber drum causing it to squeeze outward against the interior of the cardboard sanding tube. I occasionally had the "creeping tube" until I figured to tighten the srew on the end. Eureka! That was the ticket. I didn't know to crank that puppy down until the drum doesn't come off. Thank you once again, Holly! I just sanded the heck out of the San Fran with no problems, except that now I'm covered in dust. But I'm happy and don't care about that. Hooray! Quote Link to post Share on other sites
Michel by 2 Posted December 27, 2020 Share Posted December 27, 2020 Thank you for sharing! I spent an hour + chasing those little suckers around the shed until I read this. Worked on my ryobi!!! 2 Quote Link to post Share on other sites
