doclac Posted December 12, 2023 Share Posted December 12, 2023 I am new to this, starting minimadness with the Beacon, after a couple of independent room builds. Question: Some advise staining and varnishing the stair parts BEFORE assembly, others after assembly,per web research. Your thoughts appreciated! Quote Link to comment Share on other sites More sharing options...
Mid-life madness Posted December 12, 2023 Share Posted December 12, 2023 It is entirely your call. I tend to be messy with the glue, and the glue marks do not take stain.....staining first then gluing is the main reason it is done first. Quote Link to comment Share on other sites More sharing options...
KathieB Posted December 12, 2023 Share Posted December 12, 2023 3 hours ago, doclac said: Question: Some advise staining and varnishing the stair parts BEFORE assembly, others after assembly,per web research. 2 hours ago, Mid-life madness said: I tend to be messy with the glue, and the glue marks do not take stain.....staining first then gluing is the main reason it is done first. My call would be to stain before assembly and varnishing after assembly for two reasons. 1) I think the gluing stained surface to stained surface would create a stronger bond than gluing varnished surface to varnished surface. 2) The varnish or polyurethane clear coat will fill in the seams where parts fit together, eliminating the paper-thin gaps and resulting in a neater looking finished surface. Quote Link to comment Share on other sites More sharing options...
havanaholly Posted December 12, 2023 Share Posted December 12, 2023 I make a lot of my own mini furniture, too; so I definitely stain first (after carefully sanding) and then glue after the stain is throughly dry. Quote Link to comment Share on other sites More sharing options...
doclac Posted December 12, 2023 Author Share Posted December 12, 2023 Thank you to all who replied. You are in sync: stain first, assemble second. THANK YOU all! Quote Link to comment Share on other sites More sharing options...
havanaholly Posted December 12, 2023 Share Posted December 12, 2023 As Carrie says, stain and glue don't like each other. Quote Link to comment Share on other sites More sharing options...
