Rocio Posted October 30, 2006 Share Posted October 30, 2006 Hi. I know some of you use sealers on the wallpaper. I'd like to know the name of the sealers/protector. Is it a spray? I've been looking for the answer on the search option, I know I read it somewhere. I'd appreciate it. Ok, I did some more searching on google, and yay I found two. One called DecoArt, and another Krylon sealer. (I knew the word started with a k, lol). I'm going to read a little into these, I think I could use it on some wooden floor sheets I bought. Any recomondations? I should spray the paper first right? THANK YOU. Quote Link to comment Share on other sites More sharing options...
Color Me Holly Posted October 30, 2006 Share Posted October 30, 2006 I use the Krylon matte sealer. It is really up to you if you want to seal your paper. I did since I was using scrapbook paper, to help protect it from dirt. I bought the Krylon because it was cheaper here where I live. Quote Link to comment Share on other sites More sharing options...
Steve_in_PA Posted October 30, 2006 Share Posted October 30, 2006 For my wallpaper & printies, I use a spray that I got at the craft store called Grumbacher's fixative. There were several brands there, but I just happened to pick up Grumbacher's. It comes in matte or gloss finish. I dry fit & cut the sheet before I spray it. On some of my applications, I use spray adhesive that I got at Lowe's. In a tight space, this can be hard to do, since you can't move it once it's up. If you floor is real wood , I use a minwax polyurithane finish. I hope this helps you some. Steve in PA Quote Link to comment Share on other sites More sharing options...
havanaholly Posted October 31, 2006 Share Posted October 31, 2006 I bought the Krylon sealer for "stained glass" printies and now I use it on everything. I use a few light coats, rather than one heavy one. Quote Link to comment Share on other sites More sharing options...
