Beulah Posted July 12, 2017 Share Posted July 12, 2017 If I buy windows and doors or other items from Houseworks, does anyone know if they would fit Dura Craft houses. Thanks Quote Link to comment Share on other sites More sharing options...
L Swearengin Posted July 12, 2017 Share Posted July 12, 2017 Measure the window opening, then check the dimension on the window you want to order. If it's a smidge bigger the opening can be "adjusted" Quote Link to comment Share on other sites More sharing options...
Sable Posted July 12, 2017 Share Posted July 12, 2017 The window instructions offer two dimensions. One for the opening and one for the entire window size and depth. Quote Link to comment Share on other sites More sharing options...
Qubanqtee Posted July 12, 2017 Share Posted July 12, 2017 Ive never had any luck making Houseworks fit Duracraft, DC is always shorter, narrower etc etc.....if you find one that works, please post! Quote Link to comment Share on other sites More sharing options...
Guest Posted July 12, 2017 Share Posted July 12, 2017 Consider the depth of your walls too.. If you have an mdf duracraft the wall depth is compatible to pre-made windows. I think if you have one with the slot style walls you will need to pad your walls. Check out Otterine's Haunted Heritage.. she had much success using pre-made windows, but there was preparation and planning involved. http://www.greenleafdollhouses.com/forum/?app=gallery&module=gallery&controller=view&id=70544&browse=1 Quote Link to comment Share on other sites More sharing options...
Beulah Posted July 12, 2017 Author Share Posted July 12, 2017 Thank you all so much, I don't mind altering them, I was just wonder if the wall thickness would work for them, thanks Quote Link to comment Share on other sites More sharing options...
Sable Posted July 12, 2017 Share Posted July 12, 2017 Having a hobby table saw has been very helpful for this. I've had to cut the thickness down because I didn't want to pad my walls. I've also had to increase the thickness of the stock Windows and doors for the stone house by 1/2" due to the added depth of the stone I used. 1 Quote Link to comment Share on other sites More sharing options...
Qubanqtee Posted July 12, 2017 Share Posted July 12, 2017 well I do know that @samusa has cut down the trim on doors to make them accommodate the lack of thickness and there is a few doors from China that fit the width but you have to cut out for the height and modify the trim ...but the doors are nice just haven't found windows 1 Quote Link to comment Share on other sites More sharing options...
Guest Posted July 13, 2017 Share Posted July 13, 2017 53 minutes ago, Qubanqtee said: well I do know that @samusa has cut down the trim on doors to make them accommodate the lack of thickness and there is a few doors from China that fit the width but you have to cut out for the height and modify the trim ...but the doors are nice just haven't found windows LOL.. I forgot I did that.... eek... early age related memory loss??... Yes so I did cut down the inside frame of a door to fit my San Franciscan. https://blueprintminis.blogspot.com.au/2016/11/so-when-i-bought-this-door-it-didn-fit.html I have a 557 which is MDF so I didn't need to modify the depth.. but I'm sure you could cut it down also. Quote Link to comment Share on other sites More sharing options...
