Deb Posted January 2, 2006 Share Posted January 2, 2006 Hey all, I'm putting a screen door on the kitchen of the Lily. What's the best mesh to use for the screens? Deb Quote Link to comment Share on other sites More sharing options...
havanaholly Posted January 2, 2006 Share Posted January 2, 2006 I've used the plastic mesh from a bag of Mini Bel cheeses for screen inserts for a small kitchen cupboard in my Cambridge. I'm sort of partial to nylon tulle for window, door or porch screening, it looks more like the nylon/ plastic screening one sees nowadays & comes in colors that would work for mini screening. Plus a yard of it could probably be enough to screen an entire 1:12 scale house! Quote Link to comment Share on other sites More sharing options...
Nameless1 Posted January 2, 2006 Share Posted January 2, 2006 I'd join Holly's vote for tulle. It's great stuff. Quote Link to comment Share on other sites More sharing options...
Minis On The Edge Posted January 2, 2006 Share Posted January 2, 2006 Ditto what they said!! Tulle should work great and it comes in all colors! ;) Quote Link to comment Share on other sites More sharing options...
darrellandmelissa Posted January 2, 2006 Share Posted January 2, 2006 The screen door we made for the haunted house has pantyhose for the screen. I stretched it over something covered in wax papaer. I then glued ha;f of the frame to the pantyhose. When it was dry, I trimed the piece and added the other half of the screen. Melissa Quote Link to comment Share on other sites More sharing options...
havanaholly Posted January 2, 2006 Share Posted January 2, 2006 I thought I remembered y'all used pantyhose for screening, how did you keep it from running? That has always been me biggest problem, I used to make "Stumkin" dolls from old hose until the runs ran me crazy. Quote Link to comment Share on other sites More sharing options...
darrellandmelissa Posted January 2, 2006 Share Posted January 2, 2006 I stuck a piece of styrofoam into the panty hose and used pins to stretch it. It did not run. after the frame dried i just cut it with scissors the glue around the frame would keep it from running i think. If I was going to join 2 pieces of pantyhose together in a seam I think I would glue it together as I think trying to sew it would cause runs. Melissa Quote Link to comment Share on other sites More sharing options...
havanaholly Posted January 2, 2006 Share Posted January 2, 2006 Thanks, that was what I was wondering about. Quote Link to comment Share on other sites More sharing options...
Deb Posted January 3, 2006 Author Share Posted January 3, 2006 Thank you ladies! That was the information I needed. I wonder if a little starch on the panty hose would stop it from running? I'll give it a try and see what happens. The tulle is a great idea and got me to thinking about a house with a screened in porch. There's a southern dwelling in that idea somewhere! Thanks again! Ya'll are just the best! Deb Quote Link to comment Share on other sites More sharing options...
Anna Posted January 3, 2006 Share Posted January 3, 2006 As far as stopping running masks in stockings (you know when wearing them and discoveing there is s light run..) I have put a small dab of clear nail varnish just above where it started and it keeps it under control so perhaps that might work in this case as well? Hugs Quote Link to comment Share on other sites More sharing options...
havanaholly Posted January 3, 2006 Share Posted January 3, 2006 That thought had occurred to me, but then I remembered the time or two I tried it, it stops the run but also stops the stretch there & I wound up with more runs/ rags when I tried to recycle the stocking (I had a dear friend who crocheted them into scrubbies). Quote Link to comment Share on other sites More sharing options...
