Building door frame for kit door - open
otterine
I'm keeping the original kit door, but the instructions have you glue the door in place whereas I want a working door. Houseworks doors are a different size than the kit door, so I couldn't use an existing frame on the kit door.
The kit door has been assembled without the glass insert and pane detail for now. The kit door had only one lower rectangle detail, so I cut another for the other side. To make the frame, I used a Houseworks door for reference. Unlike the Houseworks door, though, I won't have exterior and interior trim. Instead, the door will be built into the recessed entry and have trim only on the interior. The door has one coat of Black Plum by Americana. It's more brown than I wanted, so I'll top it with another color. Like the Houseworks door, I curved one edge of the door using a metal file.
I used 3/16" x 3/8" basswood for the top and sides. The bottom of the frame is made from 1/8" x 3/8" basswood. The frame is built close around the door while allowing it to move freely. After making the pocket door for the Heritage, I had an extra set of hinge pins. I drilled holes in the kit door and finished fitting the frame with those in place. It works! :D
The Brownstone
· 107 images
  • 107 images
  • 364 image comments
Wonderful. Can't believe I never figured out the curved edge before. Of course, it makes perfect sense. It's a "duh" moment for me. Thanks for pointing it out.
You have inspired me to try this... I have the WORST time with doors if they are not already hinged for me.... I love how you did this :)
