mygrommi Posted April 26, 2007 Share Posted April 26, 2007 Is it possible to groove MDF with a Dremel tool like you can on plywood in order to use the round wire method of lighting my San Franciscan? I'm very familiar with the round wire method and have never used the tape method. I also have lots of the round wire materials. Thanks. Renea mygrommi Quote Link to comment Share on other sites More sharing options...
nuttiwebgal Posted April 26, 2007 Share Posted April 26, 2007 I guess we wont know till you try! try it on a peice of scrap first....maybe the underside of the house? good luck! nutti :groucho: Quote Link to comment Share on other sites More sharing options...
havanaholly Posted April 26, 2007 Share Posted April 26, 2007 Renea, do you really want to cut grooves in MDF? Tracy has built MDF kits, I believe, and she uses the round wire, so perhaps she can help you. Quote Link to comment Share on other sites More sharing options...
mygrommi Posted April 27, 2007 Author Share Posted April 27, 2007 How do I find Tracy? If there is a better way to use the round wire method with grooves I want to know about it and how it is done. Renea mygrommi Quote Link to comment Share on other sites More sharing options...
nuttiwebgal Posted April 27, 2007 Share Posted April 27, 2007 Tracy is MinisOnTheEdge our forum administrator! did you try it yet? nutti Quote Link to comment Share on other sites More sharing options...
havanaholly Posted April 27, 2007 Share Posted April 27, 2007 Thanks, Nutti, I don't know where my brain goes dancing off to, some days! Renea, go to one of Minis on the Edge's posts and click on the bar on the left with her user name and you'll get a dropdown menu with an option for sending her a message, and you can PM her from there. Quote Link to comment Share on other sites More sharing options...
doogster Posted April 27, 2007 Share Posted April 27, 2007 You definitely could groove MDF with a Dremel, You'd just need a groove cutter (1 of their router bits) and the plunge router attachment. I think the hard part would be laying it all out before assembly, because it would be a pig after. And you should wear a dust mask, like I didn't when I cut the new staircase opening in Marg's MDF DuraCraft. Why the router attachment? Believe me doing it freehand? How many parameter's do you enjoy controlling all at once? No left to right guide, nothing to control depth of cut. With the router attachment and a well layed out plan, It'd fly. Quote Link to comment Share on other sites More sharing options...
mygrommi Posted April 27, 2007 Author Share Posted April 27, 2007 Doogster, my house is already assembled - I bought a store model, so using the router attachment won't work since I won't be routing flat boards. It will all be done inside the house. Thanks Renea mygrommi Quote Link to comment Share on other sites More sharing options...
havanaholly Posted April 28, 2007 Share Posted April 28, 2007 Renea, a very sharp set of chisels/gouges and start with a straight edge and a very sharp knife and a small hammer, and practice on any scraps of MDF you might get a hardware store's lumber manager to part with. Quote Link to comment Share on other sites More sharing options...
Boxoftrix Posted June 29, 2007 Share Posted June 29, 2007 I did it on mine Renea, I used a a small needle file and a hammer to chisel a trench in each floor for the light fitting below and I used my dremel to bore the hole for wire to the light fitting. Yvonne Quote Link to comment Share on other sites More sharing options...
