blue_moon992 Posted October 19, 2006 Share Posted October 19, 2006 I got some itty bitty hinges for the Willow front door.......how in the world do you attatch them??? Is there some unwritten code that I don't know about lol Any suggestions appericated!! :thanks: Quote Link to comment Share on other sites More sharing options...
Color Me Holly Posted October 19, 2006 Share Posted October 19, 2006 I got some itty bitty hinges for the Willow front door.......how in the world do you attatch them??? Assuming they are metal hinges, super glue works well for attaching metal to wood. Quote Link to comment Share on other sites More sharing options...
havanaholly Posted October 19, 2006 Share Posted October 19, 2006 itty bitty hinges for the Willow front door.......how in the world do you attatch them? Ooo, I don't like them! If you don't "seat" them meticulously, they bind. The heads of the little brads ("nails") are rounded, so that also makes them bind. If you want to prevent them popping loose (I've used superglue, both liquid & gel, as well as other glues, and still had them pop loose) you will be tempted to use the brads; fastening them into the hinges without popping the hinges loose often bends/ distorts the hinge so it binds. This is why I hinge my doors with strips of chamois or twill tape (methods described in my team building blogs), or check out Peggi's team building blog for her Coventry Cottage to see how she used pins. Quote Link to comment Share on other sites More sharing options...
blue_moon992 Posted October 19, 2006 Author Share Posted October 19, 2006 Ohhh thanks! What great ideas!! Think I am going to try glue and as long as it holds, thats all I'm concerned about cause I'm selling the house anyway, and, as long as it holds up till it gets its new home, I am happy as can be!! :thanks: Quote Link to comment Share on other sites More sharing options...
Charlene Posted October 22, 2006 Share Posted October 22, 2006 You can insert the brads into the hinges doing this: Drill a tiny hole where the hinge will be 'nailed' -- drill a hole for each hole in the hinge. Glue the hinge on (I've found that tacky glue holds nicely). Put a dab of glue on the brad. Insert the brad thru the hinge's holes. The brads won't actually be holding the hinge -- the glue will -- but the holes will be filled in neatly and look right. Quote Link to comment Share on other sites More sharing options...
