Cuppa-Tea Posted September 14, 2006 Share Posted September 14, 2006 I was looking for one of these today, and couldn't find one in the store. Before I order one online, I have a quick question. Does it only miter things that are flat (like window casing) or will it also miter trim that has to be cut diagonally on the edge, such as crown molding or chair rail? Quote Link to comment Share on other sites More sharing options...
Minis On The Edge Posted September 14, 2006 Share Posted September 14, 2006 Yes you can use it for trim & chair rails too . You'll love it! Quote Link to comment Share on other sites More sharing options...
Anna Posted September 14, 2006 Share Posted September 14, 2006 indeed!!!! I just love mine and am using it more and more as I see how quick I can move on instead of taking out that mitre box and saw.... Hugs Quote Link to comment Share on other sites More sharing options...
wenlaine Posted September 14, 2006 Share Posted September 14, 2006 I sure wouldn't be without mine! Quote Link to comment Share on other sites More sharing options...
hydroped Posted September 14, 2006 Share Posted September 14, 2006 Crown moulding and baseboard can be a little tricky to mitre but it Will do it I generally just use a small scrapwood backing and cut through both pieces together. You'll love your Easy Cutter! -David Quote Link to comment Share on other sites More sharing options...
Cuppa-Tea Posted September 14, 2006 Author Share Posted September 14, 2006 Crown moulding and baseboard can be a little tricky to mitre but it Will do it I generally just use a small scrapwood backing and cut through both pieces together. You'll love your Easy Cutter! -David I see you understood my question. Thanks for the tip about scrapwood. I was wondering how to keep it from being crushed. I may just use my mitre box for those. Quote Link to comment Share on other sites More sharing options...
hydroped Posted September 14, 2006 Share Posted September 14, 2006 Hi Christine, Actually I haven't had any problem with the cutter crushing my baseboards and crown molding - the blade is really sharp and cuts really well - the problem I've had is that the wood tends to want to bend just a little as the blade pushes into it, so even thought I carefully line up the angle as the blade is coming down the wood is so thin it wants to move away from the blade just a bit and give me a bit of a funky angle - which cleans up Super easy with a bit of sandpaper or a dremel! That's why I use the backing to give the wood some extra support so it doesn't move as much - it helpes the angle comes out cleaner on those super thin angle cuts. David Quote Link to comment Share on other sites More sharing options...
