nuttiwebgal Posted July 7, 2006 Share Posted July 7, 2006 I have some flooring I want to glue down to the kitchen floor it is wood. I should use wood glue? and does this stuff warp? it is wood parquet. and it fit perfectly into the house Im putting it in. I should lay heavy objects on it while it dries? some advice please. oh and what would be a good way to finish it? I was thinking....a light sanding....a good rub with brown bag....and than a couple of coats of polyurethane? no stain coz the colors are already perfect. nutti Quote Link to comment Share on other sites More sharing options...
Charlene Posted July 7, 2006 Share Posted July 7, 2006 Hi! I used wood glue for the parquet that I used in 2 rooms of my colonial and I did not have any warping with it. Now this was pre-stained (lovely dark oak) so I used just two coats of poly with sanding between the coats and it turned out lovely. Shouldn't have a problem with warping if you're not staining it (not enough moisture to cause the warp, I think). But, as it's always better safe than sorry, you might place a book on top of it when you glue just to be sure. Quote Link to comment Share on other sites More sharing options...
havanaholly Posted July 7, 2006 Share Posted July 7, 2006 I have some flooring I want to glue down to the kitchen floor it is wood. I should use wood glue?If your flooring is laminated to a paper backing you can use wood glue or doublesided tape. and does this stuff warp? it is wood parquet. and it fit perfectly into the house Im putting it in. I should lay heavy objects on it while it dries? That way you know it'll dry flat oh and what would be a good way to finish it? I was thinking....a light sanding....a good rub with brown bag....and than a couple of coats of polyurethane? Try a light coat of clear sealer and when it's thoroughly dry if it looks "fuzzy" you can hit it with some 600 grit or finer sandpaper and if not, then a good brisk rubdown with the grocery sack & then poly if you want a basketball court gloss. And pictures, of course! Quote Link to comment Share on other sites More sharing options...
