kreativitea75 Posted August 5, 2010 Share Posted August 5, 2010 I bought a pre-built Beacon Hill on CL for a steal! The problem is that several steps I would have taken to decorate while putting it together were ommitted. I have already had to sacrifice the stairs, which were installed before flooring or wallpapering were done. My real problem is the roof. First, can those strips of wood shingles be used on the BH, or should shingles be applied one-by-one? Also, there is a nook of roof that was not shingled, and now this small angled area is tough to get to because it is right next to the tower (I'm including a pic). Any ideas on how to shingle this area? Any and all ideas greatly appreciated! Quote Link to comment Share on other sites More sharing options...
madtex1967 Posted August 5, 2010 Share Posted August 5, 2010 The best thing I can think of to shingle that area of the roof is to make a paper template, as you would for flooring or wallpaper. Simply tape pieces of paper together that will fill the space (as best as possible). From that you can make a clean, one piece template. I use graph paper since the lines are already there, and you can glue the shingles to the template. I did this on my Garfield for the shingles in the areas, and it worked perfect. ALl you have to do then is glue in the solid piece on the roof. Quote Link to comment Share on other sites More sharing options...
pin1056 Posted August 5, 2010 Share Posted August 5, 2010 or....long tweezers to get them in...i did that...it worked but geeze the template idea woulda been easier Quote Link to comment Share on other sites More sharing options...
kreativitea75 Posted August 6, 2010 Author Share Posted August 6, 2010 The template idea sounds good - and the graph paper is super smart! Thanks so much! Quote Link to comment Share on other sites More sharing options...
