prariegurl Posted January 21, 2009 Share Posted January 21, 2009 Last fall at Philadelphia Miniaturia, DH bought me a lovely Arts & Crafts fireplace from Kummerows. It will occupy a place of honor in the Bungalow living room. Now here's my dilema. I simply will not have a fireplace without a corresponding chimney on the outside of the home. I have already finished the siding on the house. So what would be the best way to add a chimney to an already sided dollhouse? Jeri Quote Link to comment Share on other sites More sharing options...
havanaholly Posted January 21, 2009 Share Posted January 21, 2009 Draw out the Chimney the size you want it and make a cardboard pattern, lay it on your wall where you want it & trace around it, use a sharp knife to cut through the siding and remove it from inside the traced/ cut lines. You can use your pattern to make the pieces for your chimney out of foamcore or wood and add it onto the exterior of the house, finishing it in whatever way you wish. Quote Link to comment Share on other sites More sharing options...
prariegurl Posted January 23, 2009 Author Share Posted January 23, 2009 Thanks, Holly. At least now I know what I have to do. I had hoped there would be a way to do it without chipping off the siding, but as in most things worth doing, there's and easy way and the right way. Quote Link to comment Share on other sites More sharing options...
havanaholly Posted January 23, 2009 Share Posted January 23, 2009 You'd only need to remove enough siding along your trace line to accommodate the thickness of the material you're using for your chimney, to get a flush fit to the wall, but IMO it's just easier to peel off the siding strips inside where the chimney will go. Quote Link to comment Share on other sites More sharing options...
justmesue Posted February 5, 2009 Share Posted February 5, 2009 Holly's way works great! I had to do this to add a chimney to my cabin roof, after I stupidely forgot it had one, and shingled the roof. Quote Link to comment Share on other sites More sharing options...
