laura wendy Posted January 27, 2008 Share Posted January 27, 2008 I have the magnolia house. In the instructions i need the front bay wall from sheet 1. Well the front bay wall doesn't look like it is on the sheet. I looked at the sample sheets on the paper and they don't match the wood sheet #1. Help????? Quote Link to comment Share on other sites More sharing options...
nuttiwebgal Posted January 27, 2008 Share Posted January 27, 2008 do you have a wood sheet number 1?? all the sheets should have numbers. if you go through them and do not have a #1 sheet if its a new kit you could than contact Greenleaf for a replacement. good luck! nutti Quote Link to comment Share on other sites More sharing options...
havanaholly Posted January 27, 2008 Share Posted January 27, 2008 The numbers are stamped into the corners of the plywood sheets. I always go through each plywood sheet and compare it to the schematics sheets to be sure I have everything that's supposed to be there. Quote Link to comment Share on other sites More sharing options...
laura wendy Posted January 27, 2008 Author Share Posted January 27, 2008 Yes I do have all the sheets of wood. But Wood sheet #1 doesn't have the same parts as the instructions say or show. I have built one before, and this is more challenging then the first one. I have sitting here for days trying to figure out why the sheets don't match up. Quote Link to comment Share on other sites More sharing options...
Peggi Posted January 27, 2008 Share Posted January 27, 2008 Does any of the sheets match the schmatics? Try to ignore the no., but see if the layout is the same and if so renumber lightly in pencil. If no sheets match and you bought this from someone other than a retailer, they may have mixed up the kits. If you got it from a retailer, I'd take it back. Quote Link to comment Share on other sites More sharing options...
havanaholly Posted January 29, 2008 Share Posted January 29, 2008 Oh, I hadn't even thought of that! WTG, Peggi! I wonder which kit it might be, if it's not the Magnolia? Quote Link to comment Share on other sites More sharing options...
