rbytsdy Posted November 3, 2007 Share Posted November 3, 2007 Hi folks, I am toodling along with the Pierce exterior, and decided not to use the gingerbread trim that is supposed to go atop the roof apices. Instead I put painted dowel: As you can see, my roof pieces are not aligned to each other very well, and in the first picture, the dowel is not even sitting straight. In the second picture, the roof pieces meet each other in the middle of the roof line, but diverge again toward the ends, so that the dowel is seated toward the ends, but perches in the middle... I've been ruminating over how to cover up this misalignment, and thought you guys might have some ideas... Thanks! Quote Link to comment Share on other sites More sharing options...
aggiemae Posted November 4, 2007 Share Posted November 4, 2007 If you want to leave the rounded trim removing the front trim and recut the top at an angle so they stop right at the peek, covering the front of the dowel, will make the roof look more even. You might have to cut down the dowel a bit. Another option, can you shim up the lower side of the roof then add a "V" trim to cover the shim? Quote Link to comment Share on other sites More sharing options...
rbytsdy Posted November 4, 2007 Author Share Posted November 4, 2007 If you want to leave the rounded trim removing the front trim and recut the top at an angle so they stop right at the peek, covering the front of the dowel, will make the roof look more even. You might have to cut down the dowel a bit. ... Hmmmm... This is what hubby says I should do. Sorta defeats my original vision with the dowel, but I think I already defeated myself there...! Quote Link to comment Share on other sites More sharing options...
aggiemae Posted November 4, 2007 Share Posted November 4, 2007 you can sand the top of the front trim round after it dries if you want that look, what is important is that the cuts be vertical and parallel. This will fool the eye by giving the illusion of symmetry. Quote Link to comment Share on other sites More sharing options...
