Marlene Posted August 15, 2005 Share Posted August 15, 2005 Okay, here is another question for all you pros out there. I am starting to construct my Pierce and plan on wiring this one. Where I bought the wiring kit, I was told not to prime the house as the tape would not stick as well to the paint. I have a book and it says to prime. Help!!! Which way do I go. If the answer is to prime...which is the best to use? On vacation I made a stop at Earth and Tree Miniatures in New Hampshire. My oh my oh my!!! What a shop. There website does not do justice for their shop though. It has anything and everything possibly imaginable for dollhouses. Huge amount of dollhouses set up and everything in them is for sale. Even has a separate room to sit and browse through all the binders of wallpaper they have in stock. If you can't find what you are looking for there...it probably doesn't exist. Plus, super helpful and friendly staff. If you ever get a chance...go...just go only with cash though as you may blow your card limit in there. But then again...you'll have lots of minis and what more could a miniholic ask for. Quote Link to comment Share on other sites More sharing options...
MiniMadWoman Posted August 15, 2005 Share Posted August 15, 2005 Hi, Marlene! I primed my house first. I didn't have any problems with the tape wire sticking, just be sure to press it down well. As far as which primer to use, I used just a basic interior house primer (I had it left over from a "big" house project). Quote Link to comment Share on other sites More sharing options...
wenlaine Posted August 15, 2005 Share Posted August 15, 2005 Hi Marlene, I used shellac on both sides of all my pieces of wood before taking them out of the sheets and I had no trouble with the tapewire sticking. Wendy Quote Link to comment Share on other sites More sharing options...
William Posted August 16, 2005 Share Posted August 16, 2005 Hi: I have always primed the walls in any house that I have done, used the tape wire and never had a problem. I do give it a light sand with a 320 grit to remove any little wood fibers that may come to the surface after you prime the walls, this should give you a smooth wall for your tape. Quote Link to comment Share on other sites More sharing options...
judithfa Posted August 16, 2005 Share Posted August 16, 2005 I, too, "prime" my walls. I use Home Depot white latex/acrylic flat interior real house paint. I buy it by the galleon and it is cheap --- and good! Quote Link to comment Share on other sites More sharing options...
