uppitycats Posted September 1, 2011 Share Posted September 1, 2011 I'm sorry to start a new thread about this, but I wanted to be sure that you master builders saw this maybe hairbrained idea: I saw the outside steps and porch, laser cut, that Greenleaf offers: http://shop.greenleafdollhouses.com/Dollhouse-Stairs.html I really like the looks of the laser cut...and since the entire dolllhouse is laser cut, I think installing "regular" stairs might look "clunky". So I thought about adapting the outside porch stairs to fit into the lighthouse. I'd leave off the porch, of course!, but use the risers, steps and railings to go from 1st - 2nd, 2nd to 3rd....and then use bits and pieces of laser cut wood (scraps from the dollhouse) to build a ladder to the tower room... Is this crazy, or do you think it would work? The walls of the lighthouse are 8 sided. Obviously these stairs don't curl, but I'd run them up one side on one level, then cross over and have a second set on the other side running to the next leve., then cross over again and a set up to the third; a hole in the ceiling of the third level, with a regular ladder going up (which actually is common in old lighthouses)... Anyway, that's my musings for the day... what do you think? Quote Link to comment Share on other sites More sharing options...
fov Posted September 2, 2011 Share Posted September 2, 2011 I can't say if they'd fit, but I think the style (with the stairs open underneath) would work better in the lighthouse then in, say, a house house. Quote Link to comment Share on other sites More sharing options...
