aggiemae Posted April 12, 2008 Share Posted April 12, 2008 Are you missing a sheet of parts or some of the loose parts, like stairs and trim? If it is the trim you can check sites that sell miniature trim or even try small trims from your local lumber yard and replace it fairly easily. It would be easier if you found matching trim, so less cutting it house actually looks great with different trims, which is common in real SF Victorians . This house has lots on angles and you will need a miter saw. Maybe some one here have the sheet you need and can make a template of the parts for you to copy? You can start a new post (in the trading post area?) and ask. Quote Link to comment Share on other sites More sharing options...
