Rawr Posted December 28, 2008 Share Posted December 28, 2008 Well I was working on the FarmHouse I have, but I needed something simpler for my first time, as an experiment. I got step A done without a problem, but I seem to be stuck on step b, attaching the front wall. The Supports (I believe that was what they were called) that go below/in the doorway are confusing me beyond belief, could someone help me please? Quote Link to comment Share on other sites More sharing options...
Rawr Posted December 28, 2008 Author Share Posted December 28, 2008 Doubles posts are aloud right? Anyways, I've got it figured out. Attatic troubles. I glued it on wrong. Carefully peeled it apart, and now can't seem to get it figured out. And not all my pieces are fitting right. Suggestions? Quote Link to comment Share on other sites More sharing options...
havanaholly Posted December 28, 2008 Share Posted December 28, 2008 Doubles posts are aloud right?You should have a "Delete" button to the immediate left of your "Edit" button. Quote Link to comment Share on other sites More sharing options...
chesterfieldzoo Posted December 28, 2008 Share Posted December 28, 2008 You should do a dry fit of all the main pieces before you glue it together. That might help. Are you sure all the pieces are facing the right way? Quote Link to comment Share on other sites More sharing options...
Rawr Posted December 29, 2008 Author Share Posted December 29, 2008 Okay, so no more double postings. And I did finaly get the roof on, after much confusion and the help of a hole-punch . I got alot done yesterday, for I am now puting the plastic window part onto the door. I should have pictures on soon and I'm guessing that the actual house construction will be done today or tomarrow. Then I will begin decorating. Quote Link to comment Share on other sites More sharing options...
