redneck princess Posted November 20, 2007 Share Posted November 20, 2007 I am hoping someone can help me. The roof fit well in dry fit, but once I primed and painted the underside (for the ceiling) and stained the upper portion, I can't get the roof to fit right. I tried fitting and glueing, and it pulled up on one side, I think I warped the wood :yes: Is there any way to fix this? And in the future, should I prime/paint, etc. after it is put together. I know I am building an older kit, so probably more problems with older wood...sorry so random, but I'm not sure what to do. Quote Link to comment Share on other sites More sharing options...
lil buttah Posted November 20, 2007 Share Posted November 20, 2007 You could fill the gap with wood filler or sand down the other side to match up. Grrrr....I wish I had more experience to help you. Quote Link to comment Share on other sites More sharing options...
Wolfie Posted November 20, 2007 Share Posted November 20, 2007 Bathtub caulk will work well too...and I really love the grout that comes in small diameter rolls as you can just press them in with your fingers and it fills gaps nicely. I also stucco my ceilings - especially the attic ceilings which fills in those gaps too. If I put the "studs" on the ceiling I stucco carefully between them and then cover the stucco with "insulation" made from long strips of dryer lint. I have this pink robe that I love to wash and it has lovely pink lint that resembles the Pink Panther type of ceiling insulation....very realistic! Wolfie Quote Link to comment Share on other sites More sharing options...
heidiiiii Posted November 20, 2007 Share Posted November 20, 2007 I have a question. When you put the one side down, and the other side is warped up, does the piece have any give to place it on the other side? I dont mean like force it and maybe break it but if you can coax it over to the other side, clamp or tape it down until the glue dries. Then fill it in like others have said with caulking or spackle. You will never know...you can hide any mistake! Quote Link to comment Share on other sites More sharing options...
MichelleG Posted November 22, 2007 Share Posted November 22, 2007 I had the same problem with my left wall. It was warped and i didn't really realize it until I went to glue it and it didn't match up. I have quite a bit of a gap on the side of the house now, but I'm building it up with spackle. I put on a layer, let it dry, add another, until it's all filled in and sand it smooth. Spackle's a good thing!! Quote Link to comment Share on other sites More sharing options...
