Deema Posted September 18, 2022 Share Posted September 18, 2022 I'm building the Half Scale Fairfield. I want to use the type of lights, wires and battery boxes that came with the half scale room kits I was building before. I find led lights, wires and battery boxes online that come with 3 lights. I know I will buy battery boxes that use either AA or AAA batteries. I'm just not sure which led lights and which type extra wire to purchase that will be the same as what comes with the battery boxes. I will make my own globes, lamp shades, etc. I can't afford most of the completed lights/lamps that I'm finding online. Will someone be able to help me? All help will be much appreciated. Quote Link to comment Share on other sites More sharing options...
shannonc60 Posted September 18, 2022 Share Posted September 18, 2022 Hello. I like this website for well priced LEDs and components: https://evandesigns.com/collections/hobby-leds Here you’ll find the wire you need as well as different sized LEDs. The descriptions of each LED will tell you what size battery to use it with. And if you can’t work it out, email them. I’ve found them really helpful. I also wrote this blog post about using the string LEDs for lighting in case that helps too: https://www.redcottageminiatures.com/blog/ledlighttut Yes, half scale lights are very expensive!! 1 Quote Link to comment Share on other sites More sharing options...
Deema Posted September 18, 2022 Author Share Posted September 18, 2022 24 minutes ago, shannonc60 said: Hello. I like this website for well priced LEDs and components: https://evandesigns.com/collections/hobby-leds Here you’ll find the wire you need as well as different sized LEDs. The descriptions of each LED will tell you what size battery to use it with. And if you can’t work it out, email them. I’ve found them really helpful. I also wrote this blog post about using the string LEDs for lighting in case that helps too: https://www.redcottageminiatures.com/blog/ledlighttut Yes, half scale lights are very expensive!! Thank you I will check it out. I'll also check your blog post. I'm open to doing things different ways. 1 Quote Link to comment Share on other sites More sharing options...
Deema Posted September 18, 2022 Author Share Posted September 18, 2022 14 minutes ago, Deema said: Thank you I will check it out. I'll also check your blog post. I'm open to doing things different ways. EDIT: An extra thank you. I love your string light idea. I also looked at the Evans site. I'll order from them very soon. You are a lifesaver. Quote Link to comment Share on other sites More sharing options...
shannonc60 Posted September 19, 2022 Share Posted September 19, 2022 No worries Dee. They have some really fun stuff! 1 Quote Link to comment Share on other sites More sharing options...
Deema Posted September 23, 2022 Author Share Posted September 23, 2022 @shannonc60 I just want to let you know Evans Designs in Colorado, that you recommended came through with flying colors. The were very patient, helpful and I received my order today. 1 Quote Link to comment Share on other sites More sharing options...
shannonc60 Posted September 23, 2022 Share Posted September 23, 2022 That’s awesome! And quick! It certainly makes some of these tasks easier! 1 Quote Link to comment Share on other sites More sharing options...
