Rita Posted September 3, 2006 Share Posted September 3, 2006 Hello I was wondering if anyone could tell me what type of lighting kit I would need for this house?If anyone has a link for one to buy,would you please post it.I have no idea about a lighting kit,there are so many ones for sale.Thanks so much! Quote Link to comment Share on other sites More sharing options...
Adallae Posted September 3, 2006 Share Posted September 3, 2006 Hello! For a house that size, you would probably need the a large kit, depending on how many lights you intend to have. Here's a link to the Cir-Kit kit at HBS: http://www.miniatures.com/hbs/global/Index...asp&P=72103 I recently brought my first wiring kit, and I believe the Cir-Kit tape wiring kits are the best way to get started! Quote Link to comment Share on other sites More sharing options...
Rita Posted September 3, 2006 Author Share Posted September 3, 2006 Hello! For a house that size, you would probably need the a large kit, depending on how many lights you intend to have. Here's a link to the Cir-Kit kit at HBS: http://www.miniatures.com/hbs/global/Index...asp&P=72103 I recently brought my first wiring kit, and I believe the Cir-Kit tape wiring kits are the best way to get started! Thank you so much for the link! Quote Link to comment Share on other sites More sharing options...
nuttiwebgal Posted September 3, 2006 Share Posted September 3, 2006 if you order from them before sept 5 you can use this code...pc2603 for a 20% discount on your order nutti Quote Link to comment Share on other sites More sharing options...
MiniMadWoman Posted September 14, 2006 Share Posted September 14, 2006 I have a Beacon Hill and if you're adding lighting, you may want to think about getting the 40 watt transformer. I have a 20 watt and am currently upgrading to a 40 watt. Again, it depends on how many lights you're adding (each little light counts, not just the fixture itself). I have 28 lights including two lamps and I'm thinking of adding a couple more lamps, so I'll definitely need the 40 watts! Good luck and let us know how you make out! Quote Link to comment Share on other sites More sharing options...
