    57
    93
    282,365
Contributors to this blog
Uodate on Melissa's house
darrellandmelissa
The walls went together very quickly. The roof has only the front half installed at this time. I finally got the dormers to go together the right way. There was not a problem with the directions, there was a problem with the reader of the directions. For some reason I kept gluing the narrow ends of the dormer roof together and putting that to the top of the dormer. I believe I lost cound how many times I made the same mistake.
here are pictures of the shell
I painted part of the trim a medium lavender. The other trim will be a darker shade of lavender. The walls will be painted a pale lavender. The window frames will be white.
I have not attached the windows yet as my printer is still dead. I want to papaer and cut out around the window openings instead of trying to paper around the windows once the frames are on. I plan to run glue a thin strip of painted paper to the part of the wall that is the window frame.
1 Comment
It's nice to head into this section and read up on how the experts put these houses together. You are so fast and efficient. Ray and I are making headway (and finding the work relaxing and enjoyable), but we're struggling on a lot of the "how to's". I love reading your blogs to see how smoothly things go together.
-Susanne
