JenniferKennedy Posted December 30, 2014 Share Posted December 30, 2014 working on bays today and Ive run into a bit of a problem. There are 6 pcs of exterior trim per bay (2 per window) Page 5, R. #5 says "Preassemble the Exterior Trim centering the piece with the wider opening on the part with the narrower opening. (G) The problem is that all of the pieces are the same size. There are no wider or narrower openings. In fact, I am finding that one "leg" of each piece of trim is wider than the other.... Is this a glitch? Should I just sand one down to be wider? Is there a list of errors somewhere that I can check? Thanks y'all! Quote Link to comment Share on other sites More sharing options...
Selkie Posted December 30, 2014 Share Posted December 30, 2014 If you haven't already, I'd check out Gina's blog. She is building her 2nd BH and blogs carefully all her steps. Here the link to her first BH. She has wonderful pictures and dialog. You could also PM her here through Greenleaf. Hover over her name More Minis and click Send message or go to the top right drop down menu under your name and click personal messenger and type her a note. She's very knowledgeable. This is part of her 2nd one. 2 Quote Link to comment Share on other sites More sharing options...
