marbleeyesjg Posted March 13, 2014 Share Posted March 13, 2014 I am starting the roof trim. The schematics changed and the roof panels were moved to another sheet. Now that I am working on the trim, the schematics for sheets 13 and 14 do not match the actual sheets (not even close). Am I missing a sheet that tells me what is what? Any assistance would be greatly appreciated. It is hard to tell the door trim from the roof trim. Quote Link to comment Share on other sites More sharing options...
-defunct account- Posted March 14, 2014 Share Posted March 14, 2014 I had a supplementary sheet that noted which changes were made and where, if I remember correctly it was a regular sized 8x10 page. Another thing you could do is process of elimination. Set the door trim aside, assuming they're easier to identify, and the other parts should be the roof trims Quote Link to comment Share on other sites More sharing options...
marbleeyesjg Posted March 14, 2014 Author Share Posted March 14, 2014 Thanks. I have a sheet that shows the roof panel schematics (28 a-d), but I didn't get anything that showed the new configuration of sheets 13 & 14. There isn't much different in the sizes (width). If there was, the process of elimination would be much easier. I was hoping someone out there may have the cheat sheet. :o) Quote Link to comment Share on other sites More sharing options...
-defunct account- Posted March 14, 2014 Share Posted March 14, 2014 You know, I seem to remember having the stack of trims and just puzzling them together to fit around the rooflines. Then again, I had bought additional doors and if I goofed it wasn't as crucial. Sorry I couldn't be more help here. Keep checking in, someone mid build might be able to help clear it up for you. Good luck !! Quote Link to comment Share on other sites More sharing options...
marbleeyesjg Posted March 14, 2014 Author Share Posted March 14, 2014 Thank you so much. I did the "contact us" at Greanleaf to see if they have a supplement. Quote Link to comment Share on other sites More sharing options...
