3/21/06, the siding is on
Two coats of my bug juice turned the siding the basic color I wanted and then I painted it with a wash; I dipped the tip end of the brush into the primer & then into water & brushed it on. The finished result is a well-weathered exterior that looks like it has sat through a few S GA summers (& autumns, & winters...).
I hung the front door and glued on some of the anaglypta wallpaper border I found in a thrift shop, and when everything is nice & dry I'll paint the ceilings and cut down some of the leftover siding into baseboards.
I crocheted a little doormat while I watched "NYPD Blue" rerun on TNT.
Next I primed the roof & bay trim, and when it's all dry I'll do a dry-fit & trace around the roof part so I can make a pattern for the felt & install it.
Then I'll paint the trim green & install it when it's time.
