    68
    94
    14,923
Vents and Chimney....continued
Debra from Olde Cape Cod
Well, let's finish our latest project! Remember yesterday when I was glueing flat backed crystals to the "sheet metal"? This is what it looks like now after three coats of Gunmetal Gray metallic paint:blogentry-3022-0-00877400-1435103724_thu
The plumbing piece now has 3 coats of Antique Copper metallic and Brass metallic paints: blogentry-3022-0-60210400-1435103707_thu I know what you're thinking, it doesn't match the other one! After a couple of coats of Matte nailpolish, we're good! blogentry-3022-0-24433300-1435103770_thu
So on to the piece of 2x4. After priming it, I coated the wood with a thin layer of Elmer's White glue and applied brick paper. I figured if the white glue made the paper crinkle a little, it would just look more realistic. Came out the way I wanted: blogentry-3022-0-08746400-1435103746_thu
Now to finish the chimney cap. I cut strip wood to fit around the top of the chimney and glued it to the bottom of the piece of wood I cut and had added the "sheet metal" to.: blogentry-3022-0-84567600-1435104066_thu
Dug out some more flat backed crystals and glued them on. blogentry-3022-0-44023400-1435104098_thu
Two coats of black paint made the crystals look like rivets. A quick dry brush with Gunmetal Gray metallic made the cap look more like metal. The Captain was relieved that he didn't have to have sparklies on his Summerhouse! LOL! blogentry-3022-0-51936000-1435104137_thu
Once all glued together, this is the new set of cowl vents for the Steampunk Summerhouse! blogentry-3022-0-66060300-1435104161_thu What shall we tackle next?! Have a great evening all!
1 Comment
