    68
    94
    14,937
This is a drill, this is a drill....
Debra from Olde Cape Cod
The light finally came on the other day...."Hey, I have a rotary tool!" So I dumped out the box of attachments and looked for a small drill. Sure enough, there was one just a little bigger than the one in my pin vise. blogentry-3022-0-23706700-1434293117_thu Also made good use of the little vise that's kinda been kicking around for quite awhile. After drilling a few holes on the end of the steps, I lined up the small pieces with pins to see how they fit. blogentry-3022-0-02238200-1434293276_thuI'll have to cut the pins shorter, but I think this is going to work! I'll just drill the holes is the tiny pieces with the pin vise and use the rotarty tool on the rock maple step pieces. Also found some nice diamond plate images and sized and printed out what I needed. I chose a color that closely matches the silver paint on the side pieces. blogentry-3022-0-10662700-1434293515_thu So the experiment continues! And don't forget to wear your eye protection when you use power tools: blogentry-3022-0-67183000-1434293620_thu Have a great day all!
2 Comments
So, do you think my Dremel could do this? I have dozens of micro bits that I bought to go with the defunct China drill. I've always been scared to death of the cutting tools on the Dremel because they skitter all over the boards on me. It's been sitting in a plastic tub with all the accessories and shoved in the back of the closet. Hm-m-m-m?? Maybe I should investigate ....
