Tako's Blog
    9
    4
    5,596
Still making mistakes
Tako
Sooo, even with all my care yesterday because of my previous mistakes, I still made more of them. Not too terribly huge, but tabs ended up in the wrong places. I ended up with slots that had no tabs to fill them and tabs that had no slots to fit into. House fit together just fine, but now I have tabs to whittle and sand off and slots to fill and sand. I could have fixed it, but I was NOT taking the blasted thing apart for a second time, and gluing it together for a third.
So much for getting this blasted house put together and mostly finished before my break from school was over! :wub:
Possibly will edit this post with some pictures this evening, though I'm not sure -why- :ohyeah:
4 Comments
Ouch, the whole process sounds so painful! I really appreciate you blogging the process, as the Buttercup will be my first build, too! It's good to know what to watch out for!
Basically so far I figured out that if you're as accident/mix-up prone as I am, the dry fit process is probably a very good idea. It was something that I didn't really do. I just made sure the tabs and slots for each wall would line up as I was gluing.
I think for my next house I will be dry fitting and then labeling all my bits and pieces with a pencil on the side that is to face out, and which side should be the left and right and such, so I can keep myself straight while gluing!
Thanks! Yes, I did do a dry build, and before I take it back apart I'll be making a lot of notes on the wood! Then I'm planning to move the front entrance so I'll have my own kinds of mistakes to make! ;)
