Fireplace light bulb
I will electrify this house too and will start by showing how I added the light bulb to my fireplace. I edit my houses as I go along and this blog will show you the method of my madness LOL .First, I drilled a hole in the floor with my little hand drill (power tools bite. With the hand drill I have more control ;) ).I also used my hand drill to put a hole in the fireplace itself and then I fed the wire from the light bulb in the hole and through the floor to make certain that it is the correct size. I will make glowing embers later and show you all how it's done. I set the fireplace aside till later because I have to add my wallpaper to the walls. This is the one I chose for the fireplace room.Complements of My Mini Shop
