    2
    0
    1,630
Flower Tute Pictures of Steps
Shelly N
Supplies
Step 1
Flower Complete, twist stem and remove from tool
Petals Opened up and Flattened
Shaped Petals
You can mix your glue and paint together to paint the petals and leaves. Also paint front and back of the leaves but just paint the front of the flowers. Shape one set of the three petals up and the other set down.
You need to make 2 sets of 3 petals for an Iris. When painted and dry add your feathers *yellow* and then put the up part of the flower over the down petals and twist stems together paint the stems same color as your leaves. When leaves and stem are dry twist the two together. This gives you a good strong stem to plant in your garden, pot or whatever!
Hope this helps some of you. Since I am so new to this still I hope i did ok explaining.
