kellee Posted February 8, 2007 Share Posted February 8, 2007 Ok, I have been trying to make the little round tables.. and I got it figured out.. but I cant seem to get the hem looking decent at the bottom. So I was wondering if Fabric glue is better to use than tacky glue for the hem.? I used Tacky glue and it made it very stiff at the bottom... Will the fabric glue make it stiff as well? Or should I even do a hem?.. or just put fray check around the bottom, and put a thin piece of craft ribbon along the bottom... I want it to look like a finished bottom. any ideas? I really appreciate any help... Thank You Kelly Quote Link to comment Share on other sites More sharing options...
heidiiiii Posted February 8, 2007 Share Posted February 8, 2007 Fabric glue can stain thru if you use too much of it. So if you do use it, do so sparingly. If you like the way it looks, I would fray check it and put the border on. Quote Link to comment Share on other sites More sharing options...
TinyJudi Posted February 8, 2007 Share Posted February 8, 2007 I use tacky glue on fabric, but that was because it was what I had at the time. It does stiffen the fabric, so I don't think it would give the tablecloth fabric the 'fall' that you desire. Unless you can perma ruffle it a little around the bottom. Sorry, not much help. I do look forward to seeing some pics though. Quote Link to comment Share on other sites More sharing options...
Shakyshaky Posted February 8, 2007 Share Posted February 8, 2007 I would go with the fraycheck and ribbon. You may also want to look into fusable web. You just iron it in place and it will not yellow like glue. Quote Link to comment Share on other sites More sharing options...
kellee Posted February 8, 2007 Author Share Posted February 8, 2007 Thank You very all much... I am going to just use the fray check and put the thin ribbon around it. I cant find really thin eyelet lace so I will just do the thin craft ribbon,It wont be fancy but it will be more finished looking.! Heidi, How is your back? Hope you are feeling better today.! Mini Hugs Kelly Quote Link to comment Share on other sites More sharing options...
kellee Posted February 8, 2007 Author Share Posted February 8, 2007 I would go with the fraycheck and ribbon. You may also want to look into fusable web. You just iron it in place and it will not yellow like glue. Would the fusible web work for a hem of less than 1/4", making the hem was the hardest part... I really got frustrated with it... Thank You, Quote Link to comment Share on other sites More sharing options...
Shy Spirit Posted February 8, 2007 Share Posted February 8, 2007 I like using Fabric glue with fabric - there are many different kinds, washable, flexible, for applique, etc. Quote Link to comment Share on other sites More sharing options...
Shakyshaky Posted February 8, 2007 Share Posted February 8, 2007 Fusable web cut be cut to any size you want. You could even cut it in a circle if you wanted. place the web where you want it, then fold over the hem and iron. It may take a few miniutes to do but once ironed it stays by itself. Quote Link to comment Share on other sites More sharing options...
kokkie Posted February 8, 2007 Share Posted February 8, 2007 Hi Kelly, I do not know if this something for you but I use sugar-water, when dry it is stif but not so as with glue, have fun, Wilma Quote Link to comment Share on other sites More sharing options...
heidiiiii Posted February 8, 2007 Share Posted February 8, 2007 Your welcome. Back is still stiff but doing better. Thanks for asking. Quote Link to comment Share on other sites More sharing options...
Lisa R. Posted February 8, 2007 Share Posted February 8, 2007 I prefer to use Crayola glue on fabrics. Lisa R. Quote Link to comment Share on other sites More sharing options...
