TinyJudi Posted January 16, 2007 Share Posted January 16, 2007 Well, here I am, only three pieces into the Glencroft and I have a problem and a question. I have attached the base foundation and the back edge. They went together very nicely. This morning, I went to fit the right wall. It went into the tabs perfectly, however, it does not line up with the bottom of the base. Here is a photo of what I mean. It is only 1/8th of an inch, but in building, that can be ALOT. Is this something I need to worry about? Should I ignore it for now and see what happens with the other pieces or should I attempt to fix it? Has this happened with anyone else? Thanks for any help. Quote Link to comment Share on other sites More sharing options...
havanaholly Posted January 16, 2007 Share Posted January 16, 2007 Judi, I dry-fit it all together up to just before installing the second floor, to check for that sort of thisg, and I think I fit the right wall to the first floor before I did anything else (I made a book for that one & that's what the pictures show). quite often I find myself taking the dry-fit apart & juggling pieces. I did a bit of shaving on the tabs & slots with the Glencroft, as well as cosmetic surgery later on in the build. Try fitting the right wall first, and then the rest of it. Quote Link to comment Share on other sites More sharing options...
Blondie Posted January 18, 2007 Share Posted January 18, 2007 I know that small problems can lead to big problems later, but I wouldn't worry about it too much. You can always adjust everything else in the process of building. I have a wonky wall that I've had to make adjustments for on my BH, but I've been able to shave here and there and push/shove and it has worked out. I wouldn't let this stop ya. Quote Link to comment Share on other sites More sharing options...
