Flo Posted November 19 Share Posted November 19 I am planning to create a doll house from scratch using as much recycled material as possible. Is it possible to create individual rooms and then assemble or does that make it structurally unsound? Quote Link to comment Share on other sites More sharing options...
havanaholly Posted November 19 Share Posted November 19 If you use thin wood for your common walls and glue the walls together (having already cut out your doorways and having them match up) you should be good to go. Quote Link to comment Share on other sites More sharing options...
MamaV Posted November 19 Share Posted November 19 13 hours ago, Flo said: I am planning to create a doll house from scratch using as much recycled material as possible. Is it possible to create individual rooms and then assemble or does that make it structurally unsound? Welcome! Good for you! I think so long as whatever materials you use for the walls are glued together with the proper glue, you'd be fine. Quote Link to comment Share on other sites More sharing options...
