J_Sea Posted September 28, 2022 Share Posted September 28, 2022 Hi all. Can anyone tell me the best way to cut a sheet of windows from a kit into the individual panels? Is a sharp craft knife and ruler/straight edge best? I’m nervous so thanks for the help!! Quote Link to comment Share on other sites More sharing options...
havanaholly Posted September 28, 2022 Share Posted September 28, 2022 It might help to control the acetate sheet if you first tape it down over your cutting mat with masking or painter's tape. The window inserts are usually perforated, so you would only be cutting the itty bits that hold them in place, no? A cork-backed steel ruler/ straight edge is the best kind to use with your cutter, since the cork backing keep the ruler from slipping around whilst you're cutting. 1 Quote Link to comment Share on other sites More sharing options...
J_Sea Posted September 28, 2022 Author Share Posted September 28, 2022 Thank you!!! This is an older duracraft kit and the window sheet doesn’t seem to be perforated. I’ll definitely tape before cutting. Another question for you, holder of dollhouse wisdom 😉- have you ever done the clear nail polish trick to get frosted acetate kit windows? I think I’m going to try that with some acrylic paints to get a stained glass effect too. Thanks for you help as always!!! ❤️ Quote Link to comment Share on other sites More sharing options...
havanaholly Posted September 28, 2022 Share Posted September 28, 2022 (edited) I have successfully "frosted" acetate with nail polish remover; clear nail polish is lovely for the "bull's eye effect or for making the windows look hand made. For "stained glass" I prefer transparent water colors thinned with gum arabic. I would lay your window frames over top of the windows on the acetate sheet to see how much, if any.margin for gluing them in you have. I like Elmer's all-purpose white glue for gluing the clear acetate bits because it dries clear. Edited September 28, 2022 by havanaholly Quote Link to comment Share on other sites More sharing options...
J_Sea Posted September 29, 2022 Author Share Posted September 29, 2022 (edited) Awesome- I’m going to try these out tonight and see how it goes. Thank you!! Edited September 29, 2022 by J_Sea Quote Link to comment Share on other sites More sharing options...
J_Sea Posted October 2, 2022 Author Share Posted October 2, 2022 Thanks for the help everyone! Got them all cut out neatly and did a little stained glass! ❤️ Quote Link to comment Share on other sites More sharing options...
havanaholly Posted October 2, 2022 Share Posted October 2, 2022 Let us know when you have posted pictures. 1 Quote Link to comment Share on other sites More sharing options...
