jaxenro Posted August 15, 2022 Share Posted August 15, 2022 So I am making a matched pair of neoclassical pedestals using some really nice burl walnut I picked up but it is really brittle stuff. Even using a new blade it is almost impossible to keep it from chipping out as I cut it. One trick I used in the past was to glue the veneer on and then flood it with linseed oil to soften it and then trim it to shape but in this case I am layering the veneer so I can't use the oil until all the glueing is done as it will repel the glue Each pedestal consists of 18 separate pieces of venner so there is a lot of cutting. On some of the smaller trim pieces I have found tht soaking in water softens it enough that I can cut to slightly oversize without chipping then let it dry and glue. The water softens the veneer for cutting but doesn't interfere with gluing Quote Link to comment Share on other sites More sharing options...
jaxenro Posted August 15, 2022 Author Share Posted August 15, 2022 veneer - it even looks fragile in the pic sort of what i am making casting these two in sterling silver to inset into the wood - Adult or Autumn by Thorvaldsen - one a series of the four seasons if I like it will do another pair with all four seasons one per side 2 Quote Link to comment Share on other sites More sharing options...
jaxenro Posted August 17, 2022 Author Share Posted August 17, 2022 really hard to photo as the phone camera doesn't focus on the bust correctly but this is one of the new ones I am working on lost wax cast in sterling silver Marc Antony 1.5" overall height shown on the pedestal I am making for them I have some others in the pipeline including desk (0.75" or scale 9") size 2 Quote Link to comment Share on other sites More sharing options...
havanaholly Posted August 17, 2022 Share Posted August 17, 2022 Gorgeous! Quote Link to comment Share on other sites More sharing options...
jaxenro Posted August 17, 2022 Author Share Posted August 17, 2022 I might try the hard boiled egg trick to give it some patina antique it a bit Quote Link to comment Share on other sites More sharing options...
Mineejv Posted August 18, 2022 Share Posted August 18, 2022 Hard boiled egg ????? Quote Link to comment Share on other sites More sharing options...
havanaholly Posted August 18, 2022 Share Posted August 18, 2022 The sulfur in the egg yolk turns the silver a tarnish color. Quote Link to comment Share on other sites More sharing options...
jaxenro Posted August 18, 2022 Author Share Posted August 18, 2022 It is a gentle way to “age” silver without harsh chemicals Quote Link to comment Share on other sites More sharing options...
Mineejv Posted August 19, 2022 Share Posted August 19, 2022 Learned something new... thank you... both.... Quote Link to comment Share on other sites More sharing options...
jaxenro Posted September 1, 2022 Author Share Posted September 1, 2022 so under all that yarn is actually some of that walnut veneer wrapped around a 3/4" round dowel. Soaked overnight in ammonia it becomes really pliable ammonia works better than plain water for softening wood yes am making a pair of cylindrical pedestals with walnut burl base and something else I have yet to decide 1 Quote Link to comment Share on other sites More sharing options...
jaxenro Posted September 2, 2022 Author Share Posted September 2, 2022 before and after that first coat of oil all I was really doing was testing the ability to wrap a 3/4" dowel with veneer if I soaked it long enough and it worked like a charm 1 Quote Link to comment Share on other sites More sharing options...
jaxenro Posted September 2, 2022 Author Share Posted September 2, 2022 I was going for a vase shape looks like a bowling pin Quote Link to comment Share on other sites More sharing options...
FurMama Posted September 4, 2022 Share Posted September 4, 2022 On 9/2/2022 at 2:37 PM, jaxenro said: I was going for a vase shape looks like a bowling pin Turn it the other way and it looks like a wine glass. Either way I think you did an awesome job. Looks like a finished piece of art to me not a test piece. 😊 Quote Link to comment Share on other sites More sharing options...
